Start the car, if the alternator is "working", the rear bearing at the center position of the case, in the rear case, will have some magnetic attraction when the tip of a screwdriver is touched to it,....if there's magnetic attraction, but the output to the battery is nil,....time for a Voltage Regulator,....
If there's no magnetic attraction the alternator is kaput,..replace the alt. AND THE VR......
