Quote: im not a big fan of the exhaust dumping in front of the rear tire....any motor issue and you got oil all over the rear tires....my
cheapst.
Exactly. Also if you don't have turnouts then you are spraying condensation and unburned fuel right at the tires. Notice that when you stick your hand behind tail pipes it often gets wet. You want that on your tires?
In theory, there is no difference between theory and practice. In practice, there is.
