Engine shot of the low deck stroker with the SR heads, I had to raise the front of the motor up some( 1 inch to maybe 1.5 inches) to clear the headers off of the fenderwells with the low deck block Motor is moved back about 1 inch from stock A body location so that may be part of the fenderwell clearances with the low deck blocks
