hypothetical example...two core motors 1) 383 and 2) a 440 both have steel crank.
to do a budget rebuild (reuse block, crank, rods, heads)...assume new rings, brearings, came, intake.....I imagine the cost would be the same/similar as labor is a constant
to do a hi-po rebuild, new crank, rods, pistons, etc...again, i imagine the cost would have to be the same or similar.
that being said, why wouldnt you want to start with bigger motor to begin with?
You're wasting your breath spouting logic to the illogical.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
