Well ive tried not to but since you BB guys cant agree one one thing while your trying to figure out how to make a tiny 3.75 stroke 440 motor work in the 11-s 12-s us 4 inch plus small block stroker guys are in the 9s-10s all day running less bobweight, less head flow and more rpm.
Well you've ALREADY and it's starting to bubble!! 3.75 inch, tiny, by YOUR standards I guess. LEGENDARY MOTORS were built utilizing this stroke length, so now that 4 inch strokes are the rage, are we supposed to be in awe, now? I don't think so. Stroker motors are a blessing, since they produce "full race type" power at below 6500 rpm, instead of 7 to 8000 rpms. BIG PLUS, they are EXTREMELY streetable (unless you are running class). Stroker small blocks DO make a great deal of power, just as stroker big blocks do, BUT given an EQUAL, LIGHTWEIGHT chassis, the comparison could be VERY close IF both motors are nearly close in power output, not neccesarily in engine size. One motor could have a large bore, moderate stroke and have a similar output as a moderate bore, longer stroke combo. It would be the rpms of peak torque and hp that would tell the tale of winning on the street vs. winning on the track.
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
