maybe the trimrings are on too tight?
I would appreciate you keep your smart ass comments to yourself. I'm trying to get some helpfull information from experienced people to a problem and your childish remarks are not needed! If you can't respond in an adult manner go somewhere else. It appears you and pinkduster clown know nothing about these cars anyway!
No sense of humor at all. You'll NEED one around here.
The reason your trim rings are too tight is because you are trying to put trim rings for a 6 inch wide wheel onto a 5.5 inch wide rim. Go see your other post.
