Sounds like a regulater problem. A relay if its failing will burn itself up pretty fast.
Does the Pump itself seem to run at a constant rpm.
The pump seems steady enuff but when I bypass it the pump and. reg. maintain about the same pressures.....like if I set the reg. to 8 psi, the pump shows about the same WHEN bypassed but the minute I plug the bypass, both gauges peg to 15+ psi.
Does anyone know what that pump is suppose to put out at max pressure... I would think that it should be well above 15 when dead headed
They say the pump should put out 14 psi which makes me think I could run it deadheaded. I`m using the Aeromotive 4-port bad dog reg. but was thinking that when I plug the bypass it not really deadheaded properly so I`ll call em now and report back. Thankxxx guys.......... ![](/ubbthreads/images/graemlins/thumbs.gif)
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
