"How do you like the cowl on your car? Can you double stack your air cleaners with that?"
Yes I could stack 2, going to run a 3" K&N. I like it. I will look better when it's body color.
well started the process of yanking the trans. Got under the car and the tail shaft is in about 5 pieces. Looked back w/ the light as I was pulling the x-member bolts and it appears it puked a cap on the drive shaft. That's why I felt the vibration get stronger and stronger I guess. Still going to pull it (maybe tomorrow) and see if anything else broke. Might not of even been the trans. every thing is done except the convert bolts and rear u-joit. It's a mess for sure.
Make sure and check the output shaft for straightness before reusing it Second thing is to make sure that the trans is the only thing hurt
Yeah the trans is going to get yanked and inspected. Still might upgrade while it's out.
