I'd recheck your numbers. Your junk sounds like it should be makeing more power for the cash spent.
Good one, BUT, my junk was a 5.7 R/T.... Hows it feel to spend $10K+ for that extra 18HP on the SRT???
Enjoy those pistons while they last....
18 HP??? Most SRTs dyno at about 360ish. 472 sounds like 112hp to me but maybe my math is bad.
If it is tuned to 13.2:1 AFR I really recomend adding some fuel to it. Those stock pistons have a very thin top ring land and burn through easily. Shoot for about 11.5. You will probably have to send the tune out and have it redone.
I think the issue here is identifying whether it was 472 at the crank or at the rear wheels. I am guessing the op meant at the wheels.
