On my 69GTX I had to unblock mine to make the stock Carter AVS choke open correctly. It gets hotter but doesn't seem to make the fuel perk problem any worse though. As was mentioned exhaust would sometime block the crossover causing the choke to close, made for some bad starting on warm engines. Back in 1970 My cousins 1970 Swinger with a 340 had that problem.
