I have had an icing incident or two with mine over the years. When the temp and humidity is just right, it will ice up and be a pain. If it does ice up, the best thing to do is to shut it off long enough for the heads to heat the intake and carb enough to defrost them.
That's the only downside I have ever seen.
Master, again and still
