Also I will be running a 727 and I am on the fence as to what gear ratio to go with. @ GTX...Saw on your build thread that someone was questioning the reliabillity of the stock carbs, have they given you any issues?
I didn't build the motor or drive it much once completed( it' was a customers car and has already been returned to him ) .
In the little bit I did drive it, they were not a problem. BUT, I never hammered into it either.
The carbs themselves had been heavily modified from stock. Including an aftermkt metering plate on the center carb , aftermkt base plates on the end carbs and the air horns on all 3 have been removed.
All in the name of performace and adjustability.
The engine had been fully dialed in and dynoed before I got it so I have my doubts the carbs will be of any issue.
