Looking at what size turbo to go with. 440 small block 9.5:1, W9 heads(unported), MPFI with FAST XFI, stainless steel manifolds T4 flange (1 5/8ths), 727, 3.23 gears.
Looking to push about 10psi on the street and 14-18psi at the track.
Looking at something in this range.
87mm 1.25 Turbine housing T4 4” downpipe.
Good? Opinions?
