NGK Spark plug gap to 13.5 compression BB #3232066
05/10/24 02:13 PM
05/10/24 02:13 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I'm running a ngk 5672A-8 #7173 sparkplug and need the gap size.
Indy 440-1 aluminum heads.
Re: NGK Spark plug gap to 13.5 compression BB [Re: Sammy] #3232075
05/10/24 03:13 PM
05/10/24 03:13 PM
AndyF Offline
AndyF  Offline
I don't mess with them, just take the plugs out of the box and run them. NGK plugs are usually gapped just fine right out of the box.
Re: NGK Spark plug gap to 13.5 compression BB [Re: Sammy] #3232077
05/10/24 03:54 PM
05/10/24 03:54 PM
SoCal
Brian Hafliger Offline
SoCal
N.A. I would set them at .035 which OOTB is what they should be close to.
Brian Hafliger
Re: NGK Spark plug gap to 13.5 compression BB [Re: Brian Hafliger] #3232089
05/10/24 05:32 PM
05/10/24 05:32 PM
gregsdart Offline
gregsdart  Offline
Originally Posted by Brian Hafliger
[quote=Sammy]I'm running a ngk 5672A-8 #7173 sparkplug and need the gap size.
N.A. I would set them at .035 which OOTB is what they should be close to. [/quote
]me too
Re: NGK Spark plug gap to 13.5 compression BB [Re: gregsdart] #3232097
05/10/24 07:16 PM
05/10/24 07:16 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
That is what I use , .035 , -1 heads . Gary
Re: NGK Spark plug gap to 13.5 compression BB [Re: Sammy] #3232130
05/11/24 02:38 AM
05/11/24 02:38 AM
It depends on which ignition and plug wires as far as how much gap I would use as well as how much compression ratio and fuel used twocents work
Post yours please up
Re: NGK Spark plug gap to 13.5 compression BB [Re: Cab_Burge] #3232348
05/12/24 04:24 PM
05/12/24 04:24 PM
gregsdart Offline
gregsdart  Offline
Post ours please up
Good point. At 15.25/1 and methanol i run em tighter, .024
Re: NGK Spark plug gap to 13.5 compression BB [Re: gregsdart] #3232365
05/12/24 06:34 PM
05/12/24 06:34 PM
The old testing standard use to be to open them up from .035 in .005 increments and keep opening it until it would start to miss or not pull hard in high gear in the 1/4 mile and then back it down to where it didn't miss up wrench scope
I've ran the old Champion race plugs as far as .090 wide with an MSD 404B box and matching Mallory coil with solid core plug wires boogie up
Re: NGK Spark plug gap to 13.5 compression BB [Re: Brian Hafliger] #3232463
05/13/24 08:50 AM
05/13/24 08:50 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We run the -7 plug gapped at .035 N/A running E85
Re: NGK Spark plug gap to 13.5 compression BB [Re: Sammy] #3232465
05/13/24 09:08 AM
05/13/24 09:08 AM
an8sec70cuda Offline
I ran R5671A-8 NGK plugs gapped .030"-.035" on a 14:1 compression Indy headed 440 w/ C12 fuel.
CHIP
'06 GMC 2500HD LBZ Duramax
