Re: NGK Spark plug gap to 13.5 compression BB
[Re: Sammy]
#3232077
05/10/24 03:54 PM
05/10/24 03:54 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I'm running a ngk 5672A-8 #7173 sparkplug and need the gap size. Indy 440-1 aluminum heads. N.A. I would set them at .035 which OOTB is what they should be close to.
Brian Hafliger
[Re: Brian Hafliger]
#3232089
05/10/24 05:32 PM
05/10/24 05:32 PM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
[quote=Sammy]I'm running a ngk 5672A-8 #7173 sparkplug and need the gap size. Indy 440-1 aluminum heads. N.A. I would set them at .035 which OOTB is what they should be close to. [/quote ]me too
[Re: Sammy]
#3232130
05/11/24 02:38 AM
05/11/24 02:38 AM
Posts: 43,275 Bend,OR USA
Cab_Burge
It depends on which ignition and plug wires as far as how much gap I would use as well as how much compression ratio and fuel used Post yours please
[Re: Cab_Burge]
#3232348
05/12/24 04:24 PM
05/12/24 04:24 PM
gregsdart
It depends on which ignition and plug wires as far as how much gap I would use as well as how much compression ratio and fuel used Post ours please Good point. At 15.25/1 and methanol i run em tighter, .024
[Re: Sammy]
#3232465
05/13/24 09:08 AM
05/13/24 09:08 AM
Posts: 13,382 Marion, South Carolina [><]
an8sec70cuda
I ran R5671A-8 NGK plugs gapped .030"-.035" on a 14:1 compression Indy headed 440 w/ C12 fuel.
