Help with 2 cam options #3228589
04/22/24 12:36 PM
04/22/24 12:36 PM
Livonia,MI
1968fury Offline OP
1968fury  Offline OP
Livonia,MI
I'm try to help a friend build a 225 slant six for a 1980 shorty van. It has a overdrive 4spd manual transmission and a 331 gear. He wants to travel In the van so has milage and easily climbing hills is a priority. I think I have narrowed it down to two cams from Oregon camshaft.
#2106
210/214 @ .050”, 254/254 adv(.020”), .434”/.444” lift(1.5:1 rocker), 108 lobe sep, 104 int c/l, -4 degrees overlap @ .050”
events @ .050”
int op 1 close 29
exh op 39 close -5
Or
#819
219/219 @ .050”, 264/264 adv(.012”), .436”/.436” lift, 110 lobe sep, 106 int c/l, -1 degree over lap
events @ .050”
int op 4 close 36
exh op 44 close –5
Any idea which one will get better gas mileage?
As of now the block is bored 30 over and the pistons are 190 in the hole. Haven't milled the heads or the block yet.
Heads have been bowl ported and valves have been back cut.
Thanks in advance
71 scamp 340 509 cam 456 gear,68 fury1 318 3spd on the tree,50 merc flathead 3x2 3spd w/overdrive
Re: Help with 2 cam options [Re: 1968fury] #3228593
04/22/24 01:04 PM
04/22/24 01:04 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The first one will pull more out of the basement the second one will make just a little more power.
No point turning a 225 much over 4200 or so without Headwork and a better intake and exhaust. The tight centerline will be great for what he wants to do. The overdrive 4 speed will be perfect for it.
I'd go with the first one, you'll never see the extra 15 hp up top in with van aerodynamics anyway. The second cam would be perfect in a light car like a 64 Valiant
WIZE
World's Quickest Diahatsu Rocky (??) 414" Stroker Small block Mopar Powered. 10.84 @ 123...and gettin' quicker!
https://www.youtube.com/watch?v=-mWzLma3YGI
In Car:
https://www.youtube.com/watch?v=PjXcf95e6v0
