I'm try to help a friend build a 225 slant six for a 1980 shorty van. It has a overdrive 4spd manual transmission and a 331 gear. He wants to travel In the van so has milage and easily climbing hills is a priority. I think I have narrowed it down to two cams from Oregon camshaft.
#2106
210/214 @ .050”, 254/254 adv(.020”), .434”/.444” lift(1.5:1 rocker), 108 lobe sep, 104 int c/l, -4 degrees overlap @ .050”
events @ .050”
int op 1 close 29
exh op 39 close -5
Or
#819
219/219 @ .050”, 264/264 adv(.012”), .436”/.436” lift, 110 lobe sep, 106 int c/l, -1 degree over lap
events @ .050”
int op 4 close 36
exh op 44 close –5
Any idea which one will get better gas mileage?
As of now the block is bored 30 over and the pistons are 190 in the hole. Haven't milled the heads or the block yet.
Heads have been bowl ported and valves have been back cut.
Thanks in advance
