Quick question
#3227169
04/15/24 12:04 PM
04/15/24 12:04 PM
Posts: 1,445 Martinsville, IN
cdwmotorsports
Martinsville, IN
For anyone that has a low deck BB and 440source stealth heads did you use a pre-built pushrod or did you make your own from a kit? I see 440source has two pre-built ones and kits too.
eBay-cdwmotorsports
Re: Quick question
[Re: gregsdart]
#3227221
04/15/24 03:18 PM
04/15/24 03:18 PM
cdwmotorsports
Martinsville, IN
Because your deck height, cam base circle, and head and gasket thickness can all be different for each build, it is best to get a measuring pushrod and find out exactly what works for your combo. I have those, the only thing changing is stock 452's to Stealth heads. I can't use the stock pushrods due to new rockers but if I don't have to custom build them it would be preferable.
eBay-cdwmotorsports
