Quick question #3227169
04/15/24 12:04 PM
04/15/24 12:04 PM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
For anyone that has a low deck BB and 440source stealth heads did you use a pre-built pushrod or did you make your own from a kit? I see 440source has two pre-built ones and kits too.
eBay-cdwmotorsports
Re: Quick question [Re: cdwmotorsports] #3227191
04/15/24 12:50 PM
04/15/24 12:50 PM
gregsdart Offline
gregsdart  Offline
Because your deck height, cam base circle, and head and gasket thickness can all be different for each build, it is best to get a measuring pushrod and find out exactly what works for your combo.
Re: Quick question [Re: gregsdart] #3227221
04/15/24 03:18 PM
04/15/24 03:18 PM
Martinsville, IN
Martinsville, IN
I have those, the only thing changing is stock 452's to Stealth heads. I can't use the stock pushrods due to new rockers but if I don't have to custom build them it would be preferable.
eBay-cdwmotorsports
Re: Quick question [Re: cdwmotorsports] #3227225
04/15/24 03:27 PM
04/15/24 03:27 PM
Cab_Burge Online work
Cab_Burge  Online Work
I use a checking pushrod and then have Manton make them the lengths I need up scope
Re: Quick question [Re: Cab_Burge] #3227229
04/15/24 03:48 PM
04/15/24 03:48 PM
Martinsville, IN
Martinsville, IN
Which series do you use? They are on the short list of companies I'm considering.
eBay-cdwmotorsports
Re: Quick question [Re: cdwmotorsports] #3227601
04/17/24 05:03 AM
04/17/24 05:03 AM
The best ones they offer for race motors, series 3 for my street and strip builds with roller cam motors having under 700 Lbs. pressure over the nose up scope
They are not cheap though, i use to buy and use Smith Bros but stop doing that several years back after getting three bad sets puke
