Re: Anyone here use SpeedMaster products?
[Re: pittsburghracer]
#3228137
04/19/24 06:46 PM
04/19/24 06:46 PM
Posts: 9,444 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Good deal. I had always thought they were one in the same but just a name change in the public view. Unless they changed in the last two years the heads all have the PCE part numbers. The sets ive got from 2012 is identical to the 2022 castings. Not sure if I have the 2012 invoice to see if it says PC or SM. Such junk castings from 2012 are still going strong and getting abused. Not that any of it matters. Ive looked at some of the stuff you have done on fabo. I should probably look on fabo but did you ever plug and re drill for offset pushrods/rockers?
STOP POTATO HATE!
[Re: Mr PotatoHead]
#3228139
04/19/24 06:50 PM
04/19/24 06:50 PM
Posts: 20,169 PA.
pittsburghracer
Good deal. I had always thought they were one in the same but just a name change in the public view. Unless they changed in the last two years the heads all have the PCE part numbers. The sets ive got from 2012 is identical to the 2022 castings. Not sure if I have the 2012 invoice to see if it says PC or SM. Such junk castings from 2012 are still going strong and getting abused. Not that any of it matters. Ive looked at some of the stuff you have done on fabo. I should probably look on fabo but did you ever plug and re drill for offset pushrods/rockers? I’ve done it an recommend not doing it. The pinch isn’t the problem. Edelbrock or Speedmaster heads can and will flow over 330cfm with a 2.08 valve without moving the pinch. Stock rocker offset.
[Re: migsBIG]
#3228889
04/24/24 09:15 AM
04/24/24 09:15 AM
Posts: 12,055 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Uncle Tony on SpeedMaster and the Chinese invasion: www.youtube.com/watch?v=cPQHbnh0Hr0I agree with much of what he has to say on this subject, but I certainly DO NOT agree with his 'fix' at the end. Do you?
Master, again and still
[Re: DaveRS23]
#3228904
04/24/24 10:35 AM
04/24/24 10:35 AM
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Hard to watch with it being so much political opinion and not much more. He also thinks we never went to the moon. Uncle Tony on SpeedMaster and the Chinese invasion: www.youtube.com/watch?v=cPQHbnh0Hr0I agree with much of what he has to say on this subject, but I certainly DO NOT agree with his 'fix' at the end. Do you?
STOP POTATO HATE!
[Re: moparx]
#3228934
04/24/24 12:40 PM
04/24/24 12:40 PM
Posts: 2,107 Byron, NY
W.I.N. Racing
Byron, NY
Speedmaster has been removed for my approved suppliers/mfg.'s list. Reference the vid posed on here recently they are not what they say they are. I realize reverse engineering/counterfeit products are a reality and more than likely I have unshiftingly purchased some, but to knowingly support such enterprises I can not do.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#3228941
04/24/24 01:09 PM
04/24/24 01:09 PM
Posts: 21,644 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
Speedmaster has been removed for my approved suppliers/mfg.'s list. Reference the vid posed on here recently they are not what they say they are. I realize reverse engineering/counterfeit products are a reality and more than likely I have unshiftingly purchased some, but to knowingly support such enterprises I can not do. Should get a list of racers together on other boards and make a group banning this and other companies counterfeiting components. Try for a name like "Racers Against Pirated Engineering Designs" as the tech thieves hate being drawn out or any kind of attention.
[Re: Mr PotatoHead]
#3229021
04/24/24 09:22 PM
04/24/24 09:22 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Hard to watch with it being so much political opinion and not much more. He also thinks we never went to the moon. Uncle Tony on SpeedMaster and the Chinese invasion: www.youtube.com/watch?v=cPQHbnh0Hr0I agree with much of what he has to say on this subject, but I certainly DO NOT agree with his 'fix' at the end. Do you? As I said; his 'fix' at the end was just nuts. But, he did make some solid points throughout.
