Re: Low deck Indy 540 on the dyno [Re: AndyF] #3225360
04/06/24 09:00 AM
04/06/24 09:00 AM
PA
moparacer Offline
moparacer  Offline
PA
Originally Posted by AndyF
Yes, his carb needs to be reworked. It is a 3 circuit Holley that hasn't been modified and the intermediate circuit floods the engine at certain throttle positions. Evidently it runs okay from him at the track because of his two step and then being WOT down the track, but it was super rich on the dyno when we were trying to start the pulls. But the engine showed some signs of being run rich so we told him to either buy a two circuit, or to get someone to rework his carb.
The dyno carb is a box stock Holley 1050 XP. It works great on every engine we use it on. Usually don't even need to change jets in it.
I had problems footbraking 3 circuit Dominators, and always converted them to 2 circuit. Not that big of a deal to do.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Low deck Indy 540 on the dyno [Re: moparacer] #3225370
04/06/24 09:45 AM
04/06/24 09:45 AM
gregsdart Offline
gregsdart  Offline
Things that come to mind are what rocker ratio, the lash amount and intensity of rhe cam, thickness of the rings, and the effect of the intake/adapter combo, and how much room for improvement there might be in those areas?
My first 440-1 build after porting the heads made over 840 hp with a similar cam but injected methanol. So i bet the things i mentioned may be holding it back from 850 hp.
Re: Low deck Indy 540 on the dyno [Re: gregsdart] #3225387
04/06/24 11:08 AM
04/06/24 11:08 AM
AndyF Online content OP
AndyF  Online Content OP
I don't think it would require much work to bump this engine up to 850 hp but the owner didn't seem interested. The engine goes in a pickup that he drag races and he runs low 9's or high 8's and is happy with it.
From what I've seen over the years only about 5% of the customers are actually interested in finding more power after a dyno session. Most customers just want to get the engine home so they can put it in the car and get back to racing.
Re: Low deck Indy 540 on the dyno [Re: AndyF] #3225395
04/06/24 11:28 AM
04/06/24 11:28 AM
fast68plymouth Offline
Did you guys do any work on that engine…….or was it just there for a dyno test?
Re: Low deck Indy 540 on the dyno [Re: AndyF] #3225420
04/06/24 01:30 PM
04/06/24 01:30 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Is it just me or are those dyno headers kind of small for 850-900 hp?
Re: Low deck Indy 540 on the dyno [Re: AndyF] #3225437
04/06/24 03:03 PM
04/06/24 03:03 PM
NC
440Jim Offline
440Jim  Offline
NC
Did the owner at least have a few ignition timing settings tested?
The combination 4150 intake with carb adapter to 4500 may have limited top rpm power capability at 540 CID.
It would be interesting to see how the HP held up past peak. It might benefit from a higher shift point.
Re: Low deck Indy 540 on the dyno [Re: 440Jim] #3225441
04/06/24 03:16 PM
04/06/24 03:16 PM
That is a good point. The 4150 to 4500 trick might work great on a 440 to 500 inch engine but not so great at 540 inches. I tested it on my 514 and the best intake for that engine was a 4500 intake. The Super Victor worked best for me. The 440-3 was okay, the 440-3x didn't make more power.
I think all runs were made at 35 degrees. I don't recall changing the timing on it.
Re: Low deck Indy 540 on the dyno [Re: fast68plymouth] #3225444
04/06/24 03:26 PM
04/06/24 03:26 PM
It got rings and bearings, upgraded to a belt drive, fixed some issues. I think the short block was built by Indy originally but I might be wrong.
Re: Low deck Indy 540 on the dyno [Re: AndyF] #3225742
04/08/24 09:25 AM
04/08/24 09:25 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Most customers don't want to spend the extra dyno money. Also, there is zero reason to test stuff that doesn't fit the car. Why test carb spacers, if you don't have room for them? What good are dyno headers if they don't fit your chassis, other than they fit the dyno?
69 GTX 68 Road Runner
