Re: Low deck Indy 540 on the dyno
[Re: AndyF]
#3225360
04/06/24 09:00 AM
04/06/24 09:00 AM
Posts: 2,499 PA
moparacer
PA
Yes, his carb needs to be reworked. It is a 3 circuit Holley that hasn't been modified and the intermediate circuit floods the engine at certain throttle positions. Evidently it runs okay from him at the track because of his two step and then being WOT down the track, but it was super rich on the dyno when we were trying to start the pulls. But the engine showed some signs of being run rich so we told him to either buy a two circuit, or to get someone to rework his carb. The dyno carb is a box stock Holley 1050 XP. It works great on every engine we use it on. Usually don't even need to change jets in it. I had problems footbraking 3 circuit Dominators, and always converted them to 2 circuit. Not that big of a deal to do.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3225370
04/06/24 09:45 AM
04/06/24 09:45 AM
Posts: 9,996 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Things that come to mind are what rocker ratio, the lash amount and intensity of rhe cam, thickness of the rings, and the effect of the intake/adapter combo, and how much room for improvement there might be in those areas? My first 440-1 build after porting the heads made over 840 hp with a similar cam but injected methanol. So i bet the things i mentioned may be holding it back from 850 hp.
[Re: AndyF]
#3225395
04/06/24 11:28 AM
04/06/24 11:28 AM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Did you guys do any work on that engine…….or was it just there for a dyno test?
[Re: AndyF]
#3225420
04/06/24 01:30 PM
04/06/24 01:30 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
Is it just me or are those dyno headers kind of small for 850-900 hp?
[Re: AndyF]
#3225437
04/06/24 03:03 PM
04/06/24 03:03 PM
Posts: 16,925 NC
440Jim
NC
From what I've seen over the years only about 5% of the customers are actually interested in finding more power after a dyno session. Most customers just want to get the engine home so they can put it in the car and get back to racing. Did the owner at least have a few ignition timing settings tested? The combination 4150 intake with carb adapter to 4500 may have limited top rpm power capability at 540 CID. It would be interesting to see how the HP held up past peak. It might benefit from a higher shift point.
[Re: 440Jim]
#3225441
04/06/24 03:16 PM
04/06/24 03:16 PM
Posts: 31,027 Oregon
AndyF
From what I've seen over the years only about 5% of the customers are actually interested in finding more power after a dyno session. Most customers just want to get the engine home so they can put it in the car and get back to racing. Did the owner at least have a few ignition timing settings tested? The combination 4150 intake with carb adapter to 4500 may have limited top rpm power capability at 540 CID. It would be interesting to see how the HP held up past peak. It might benefit from a higher shift point. That is a good point. The 4150 to 4500 trick might work great on a 440 to 500 inch engine but not so great at 540 inches. I tested it on my 514 and the best intake for that engine was a 4500 intake. The Super Victor worked best for me. The 440-3 was okay, the 440-3x didn't make more power. I think all runs were made at 35 degrees. I don't recall changing the timing on it.
[Re: fast68plymouth]
#3225444
04/06/24 03:26 PM
04/06/24 03:26 PM
AndyF
Did you guys do any work on that engine…….or was it just there for a dyno test? It got rings and bearings, upgraded to a belt drive, fixed some issues. I think the short block was built by Indy originally but I might be wrong.
[Re: AndyF]
#3225742
04/08/24 09:25 AM
04/08/24 09:25 AM
Posts: 10,022 MN
JERICOGTX
MN
Most customers don't want to spend the extra dyno money. Also, there is zero reason to test stuff that doesn't fit the car. Why test carb spacers, if you don't have room for them? What good are dyno headers if they don't fit your chassis, other than they fit the dyno?
69 GTX
68 Road Runner
[Re: AndyF]
#3230855
05/03/24 06:04 PM
05/03/24 06:04 PM
AndyF
Just for comparison, had a Chevy 540 on the dyno today and it made 920 hp. Very similar engine to the 540 Mopar. This BBC is also all aluminum, similar compression, similar cam specs, single 4 bbl intake using the same 1050 dyno carb, both were wet sump with vacuum pump, both used dyno headers, both use Jesel belt drive, crank trigger with MSD, etc. The BBC heads are just that much better. This engine uses Brodix Big Brodie 3x heads. I think they are 365 cc with a big rectangular intake port. The intake port is so big it requires a special gasket and you have to buy the Brodix intake if want it to fit out of the box.
[Re: AndyF]
#3230888
05/03/24 09:09 PM
05/03/24 09:09 PM
Posts: 5,485 SoCal
Brian Hafliger
SoCal
Those BB3 Heads are no joke! Brodix moved the valves around some (still 24°) to accommodate a larger valve without shrouding...they make power!
Brian Hafliger
[Re: AndyF]
#3230904
05/03/24 11:00 PM
05/03/24 11:00 PM
Posts: 288 NW Illinois
MoonshineMattK
NW Illinois
This is the first time I'd seen these heads. I figured the engine would make 850 hp since the compression wasn't that high and the cam was an off brand. But when we opened the throttle the engine started to howl and the needle spun on the HP gauge.
Funny thing about this engine is that the customer who brought it in bought it at the track from a guy who was pissed at poor performance. Guy was so mad he sold the engine for $10K at the track. Probably cost close to $40K to build an engine like this with all new parts. Anyone know what a Ray Barton Hemi would cost? And what power they make
