EMISSIONS CODE P0440 #2623315
02/19/19 02:30 PM
02/19/19 02:30 PM
Spring Valley ,Ca.
moparsquid Offline OP
Spring Valley ,Ca.
Good day hopefully someone has had the same problems I'm having. I have a 2003 dodge Dakota quad cab with the 4.7 and I'm constantly getting the evap code p0440 ive changed the gas cap some robber lines did a smoke test and replaced the tank leak detection pump .after clearing the code it last about a day then the light will come on again I'm pulling my hair out and I dnt wanna replace every piece in that system any help thanks
Re: EMISSIONS CODE P0440 [Re: moparsquid] #2623320
02/19/19 02:42 PM
02/19/19 02:42 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
AS long as you looked REAL good for cracks in all those hoses under truck, and did replace that vac pump thingy, that only leaves filler cap, and those usually are not bad.
Re: EMISSIONS CODE P0440 [Re: moparsquid] #2623336
02/19/19 03:08 PM
02/19/19 03:08 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
there is only 2 items left to replace the vapor tank and a pump by the battery this is getting expensive
Re: EMISSIONS CODE P0440 [Re: moparsquid] #2623359
02/19/19 03:46 PM
02/19/19 03:46 PM
md
mopars4ever Offline
mopars4ever  Offline
md
My 06 Ram I replaced a lot of items for the emission code until I finally found out the problem. It was the top of the fuel pump module was cracked. I would occasionally smell gas at the fuel filler area and decided to drop the tank. All good after that. After I talked to a former Mopar tech and he said he had seen a few like that in those years.
Re: EMISSIONS CODE P0440 [Re: mopars4ever] #2623367
02/19/19 03:58 PM
02/19/19 03:58 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
thanks ill check that area I did a smoke test but saw no leaking this is a real pain
