Modern 392 into B-body project, any articles? #2610375
01/22/19 01:01 PM
01/22/19 01:01 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
I have a buddy with a 70 Charger that wants to drop a late-model 392 Hemi into it along with a 5 speed (with no tunnel removal). He'd like to keep the original K-member.
Have any of the magazines documented a similar conversion? He'd like to learn from others that have traveled this road before.
Thanks!
1970 Dodge Challenger T/A
Re: Modern 392 into B-body project, any articles? [Re: jeff968] #2610413
01/22/19 02:11 PM
01/22/19 02:11 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Take a look in the Projects and Survivors section. I though there was someone doing this. I don't think he is going to get away without cutting the tunnel. Unless you do the Passon 5 speed transmission. For the k-frame, I think someone came out with new oil pan. But in general, I think the k-frame needs to be swapped or cut up. He could buy another, cut it up and retain the original.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Modern 392 into B-body project, any articles? [Re: jeff968] #2610430
01/22/19 02:45 PM
01/22/19 02:45 PM
K
Kiddart Offline
Kiddart  Offline
K
also check out the Gen 111 area on Moparts. lots of people doing the swap.
Thank you
Kiddart
