Roller Lifter Question #2608201
01/17/19 06:34 PM
01/17/19 06:34 PM
Pennsylvania
shantyshakinstud Offline OP
Pennsylvania
Would anyone on here know how close (or how far off) the pushrod seat location height would be on a Crane Ultra Pro 95550 vs say a Comp 829 lifter? I know that seat height on the Comp is 1.79, and down in the body. The Cranes look similar in the pic, and allow pushrod oiling.
I called Crane, and although the tech line was pleasant they could not provide me with any real measurements or specs.
I found an old post on here that said they make the top link bar to accommodate 1.80 to 2.00 lifter bore spacing on either part Crane 95550 or 65550.
If there is a Crane Vendor on here, I'm happy to give them a call and the business!
Re: Roller Lifter Question [Re: shantyshakinstud] #2608575
01/18/19 02:10 PM
01/18/19 02:10 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
When I build a mopar engine, it always gets custom length push rods. As you are finding out you never know what length you need until you have the parts assembled. So most of the time I don't even ask the tech guys I just buy and measure to make sure it will work.
Re: Roller Lifter Question [Re: shantyshakinstud] #2608587
01/18/19 02:32 PM
01/18/19 02:32 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
There is a wealth of good information on this topic and related components on B3 Racing's website. The owner, Mike is a great guy to do business with, and is happy to help you get the optimal parts. His geometry correction kits are very reasonably priced too.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's
1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: Roller Lifter Question [Re: jwb123] #2608593
01/18/19 02:38 PM
01/18/19 02:38 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Absolutely.
Some of the dimensions I've seen published for roller lifter pushrod seat heights haven't been accurate... certainly nothing I'd trust trying to pre-order pushrods before being able to measure what's actually required.
