Re: Lightweight replacement 11.75" Rotors And Calipers
[Re: 65Fury440]
#2602785
01/07/19 03:50 AM
01/07/19 03:50 AM
Posts: 571 Spring Hill Fl
65Fury440
Spring Hill Fl
Thanks Andy, I was hoping there might be some OEM style stuff that would be a little lighter. Nice brakes BTW!
[Re: 65Fury440]
#2602857
01/07/19 12:39 PM
01/07/19 12:39 PM
Posts: 14,889 up yours
Supercuda
Rock auto has slotted and drilled 11.75 rotors, look up 78 Cordoba.
As for aluminum calipers, nothing that is a direct, bolt in replacement. Several options to put other stuff on, like Andy showed you, but no "stock caliper but in aluminum" type options.
[Re: 65Fury440]
#2602953
01/07/19 02:58 PM
01/07/19 02:58 PM
Posts: 30,995 Oregon
AndyF
Thanks Andy, I was hoping there might be some OEM style stuff that would be a little lighter. Nice brakes BTW! Well Viper calipers are OEM style and they are lighter. I have brackets that bolt a Viper caliper to a '73 C body knuckle. I also have a couple sets of the '73 C body knuckles on hand. I used to make a C body big brake kit but sales were slow so I killed it off.
[Re: Supercuda]
#2603108
01/07/19 09:13 PM
01/07/19 09:13 PM
Posts: 6,560 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
As for aluminum calipers, nothing that is a direct, bolt in replacement. Several options to put other stuff on, like Andy showed you, but no "stock caliper but in aluminum" type options. Cordoba rotor won't work for a C-body. C-body rotors are 1.25" thick, B-bodies are 1". I would look elsewhere for weight savings. The less rotor mass you have the less heat handling capacity you will have which means less repeated brake application capacity. Kevin
[Re: 65Fury440]
#2603112
01/07/19 09:25 PM
01/07/19 09:25 PM
Supercuda
Missed the C body reference.
[Re: 65Fury440]
#2603240
01/08/19 01:41 AM
01/08/19 01:41 AM
Posts: 300 MA
Greg55_99
MA
[Re: mgoblue9798]
#2608874
01/19/19 02:31 AM
01/19/19 02:31 AM
Twostick
Still wishing...
Still wishing...
74 d100 rotor will work same as C body Unless he has late 72 spindles that take the bigger wheel bearings, the D100 rotors won't work. I think Dr Diff sells spacer sleeves that will convert the early 72 and back spindle to big bearings so you can use the 73 up rotor. It is also my understanding that they are now producing the 69-72 rotor in unicast so they are much less $$$ than the 2 piece rotors were but I haven't actually had one in my hands to confirm the bearing sizes. Kevin
[Re: 65Fury440]
#2613641
01/28/19 07:26 PM
01/28/19 07:26 PM
Posts: 1,404 northeast ohio
hulmule
northeast ohio
anyone know the hub diameter? have a set of spindles. plus where are you finding 11-3/4 rotors? Have a set of pin caliper brackets. need a set of slide caliper brackets for big rotors.
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
