Lightweight replacement 11.75" Rotors And Calipers #2602689
01/07/19 12:23 AM
01/07/19 12:23 AM
Spring Hill Fl
65Fury440 Offline OP
Spring Hill Fl
I have a 72 disc brake setup to convert my 65 C body from manual drums.
Went to move those things around today, wow is that stuff heavy.
Are there any sources for slotted rotors and maybe aluminum calipers?
Searched around the web for a while, didn't find anything.
I'd like to free up some weight for drag racing, but thought this group may be a good source.
Re: Lightweight replacement 11.75" Rotors And Calipers [Re: 65Fury440] #2602717
01/07/19 01:12 AM
01/07/19 01:12 AM
AndyF Offline
AndyF  Offline
Sure, no problem. Just costs money.
Re: Lightweight replacement 11.75" Rotors And Calipers [Re: 65Fury440] #2602785
01/07/19 03:50 AM
01/07/19 03:50 AM
Spring Hill Fl
Spring Hill Fl
Thanks Andy, I was hoping there might be some OEM style stuff that would be a little lighter.
Nice brakes BTW!
Re: Lightweight replacement 11.75" Rotors And Calipers [Re: 65Fury440] #2602857
01/07/19 12:39 PM
01/07/19 12:39 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Rock auto has slotted and drilled 11.75 rotors, look up 78 Cordoba.
As for aluminum calipers, nothing that is a direct, bolt in replacement. Several options to put other stuff on, like Andy showed you, but no "stock caliper but in aluminum" type options.
Don't be the exception.
Re: Lightweight replacement 11.75" Rotors And Calipers [Re: 65Fury440] #2602953
01/07/19 02:58 PM
01/07/19 02:58 PM
AndyF Offline
AndyF  Offline
Nice brakes BTW!
Well Viper calipers are OEM style and they are lighter. I have brackets that bolt a Viper caliper to a '73 C body knuckle. I also have a couple sets of the '73 C body knuckles on hand. I used to make a C body big brake kit but sales were slow so I killed it off.
Re: Lightweight replacement 11.75" Rotors And Calipers [Re: 65Fury440] #2602963
01/07/19 03:15 PM
01/07/19 03:15 PM
Spring Hill Fl
Spring Hill Fl
I can't find the part # on your website.
I found a tech article you posted to do a B body. Do you have a parts list compiled for the kit using the Viper calipers?
Re: Lightweight replacement 11.75" Rotors And Calipers [Re: 65Fury440] #2602991
01/07/19 04:21 PM
01/07/19 04:21 PM
AndyF Offline
AndyF  Offline
I don't sell brake kits anymore but I still have some spare parts sitting on the shelf. Contact Doctor Diff if you want a big brake kit. A C body kit would be a semi-custom job so extra time and money is required.
Re: Lightweight replacement 11.75" Rotors And Calipers [Re: 65Fury440] #2602993
01/07/19 04:24 PM
01/07/19 04:24 PM
AndyF Offline
AndyF  Offline
Here is what the C body kit that I used to sell looked like.
Re: Lightweight replacement 11.75" Rotors And Calipers [Re: Supercuda] #2603108
01/07/19 09:13 PM
01/07/19 09:13 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Cordoba rotor won't work for a C-body. C-body rotors are 1.25" thick, B-bodies are 1".
I would look elsewhere for weight savings. The less rotor mass you have the less heat handling capacity you will have which means less repeated brake application capacity.
Kevin
Re: Lightweight replacement 11.75" Rotors And Calipers [Re: 65Fury440] #2603112
01/07/19 09:25 PM
01/07/19 09:25 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Missed the C body reference.
Re: Lightweight replacement 11.75" Rotors And Calipers [Re: 65Fury440] #2603240
01/08/19 01:41 AM
01/08/19 01:41 AM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
Re: Lightweight replacement 11.75" Rotors And Calipers [Re: Twostick] #2607052
01/15/19 06:03 PM
01/15/19 06:03 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
74 d100 rotor will work same as C body
Re: Lightweight replacement 11.75" Rotors And Calipers [Re: mgoblue9798] #2608874
01/19/19 02:31 AM
01/19/19 02:31 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Unless he has late 72 spindles that take the bigger wheel bearings, the D100 rotors won't work.
I think Dr Diff sells spacer sleeves that will convert the early 72 and back spindle to big bearings so you can use the 73 up rotor.
It is also my understanding that they are now producing the 69-72 rotor in unicast so they are much less $$$ than the 2 piece rotors were but I haven't actually had one in my hands to confirm the bearing sizes.
Kevin
Re: Lightweight replacement 11.75" Rotors And Calipers [Re: 65Fury440] #2613641
01/28/19 07:26 PM
01/28/19 07:26 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
anyone know the hub diameter? have a set of spindles. plus where are you finding 11-3/4 rotors? Have a set of pin caliper brackets. need a set of slide caliper brackets for big rotors.
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
