2004 Sebring Transmission #2592052
12/14/18 08:48 PM
12/14/18 08:48 PM
Cruising!
Q
QuickDodge Offline OP
Q
Cruising!
Automatic transmission in a 2004 Sebring has gone bad. Not sure what the problem is, the car belongs to an elderly family member.
The car is a V6 powered Sebring 2 door coupe. (I think it's a 3.0 engine??) The garage told me a re-manufactured transmission would be about $3200 installed. The car is not worth much more than that.
Were the transmissions in these cars trouble prone? Would it be advisable to consider a salvage yard transmission? Any other ideas on how to fix it, without spending to much money?
Re: 2004 Sebring Transmission [Re: QuickDodge] #2592055
12/14/18 08:52 PM
12/14/18 08:52 PM
PA
70Duster Offline
70Duster  Offline
PA
Yes, the 2004 Sebring transmissions were prone to early failure, and yes a junkyard transmission would be the cheapest way to get it back on the road.
Re: 2004 Sebring Transmission [Re: QuickDodge] #2592078
12/14/18 09:55 PM
12/14/18 09:55 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Depends on whats wrong with it
Btw, Its a Mitsubishi based trans NOT the A604 based Chrysler trans
Re: 2004 Sebring Transmission [Re: gtx6970] #2592332
12/15/18 02:26 PM
12/15/18 02:26 PM
moparx  Offline
also, i believe the 3.0 has it's own bellhousing bolt pattern, so it must come from a 3.0 equipped vehicle.
Re: 2004 Sebring Transmission [Re: QuickDodge] #2592502
12/15/18 08:16 PM
12/15/18 08:16 PM
A727Tflite Offline
A727Tflite  Offline
2.5 and 3.0 MMC motors had their unique trans bell pattern.
Re: 2004 Sebring Transmission [Re: A727Tflite] #2592729
12/16/18 01:20 PM
12/16/18 01:20 PM
moparx  Offline
2.5 and 3.0 are the same ? i didn't know that. thanks transman !
