Tool ID
#2565461
10/17/18 05:16 PM
10/17/18 05:16 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
This crimper is stamped:
AMP Type O 16-14 59498
16-14 is likely the wire gauge but the jaws are about 3/8" diameter, a little big for that wire gauge.
Re: Tool ID
[Re: John_Kunkel]
#2565467
10/17/18 05:29 PM
10/17/18 05:29 PM
Posts: 4,712 Moved to N.E. Tennessee
GomangoCuda
Maybe it's for O gage and 16-14 is the tool number. Or maybe it came with a diffent set of dies than what is currently installed.
Re: Tool ID
[Re: John_Kunkel]
#2565554
10/17/18 08:03 PM
10/17/18 08:03 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I'm thinking it's got a different set of dies in it.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
Re: Tool ID
[Re: John_Kunkel]
#2565556
10/17/18 08:05 PM
10/17/18 08:05 PM
GomangoCuda
Agree that Amp is very big in electrical connectors and crimpers. I think it was sold as a 16-14 crimper and has had the dies changed since then.
Re: Tool ID
[Re: moparmarks]
#2565575
10/17/18 08:42 PM
10/17/18 08:42 PM
Posts: 75 Lakeland, FL
sixpakchallenger
Lakeland, FL
The "O" die is for distribution electrical connectors, typically H-taps. Probably #1 stranded aluminum to #6 solid copper to feed a transformer.
2007 Mustang GT Vert 2004 Ram 2500 QC 4X4 1971 Challenger Vert 5.7 Hemi Project
Re: Tool ID
[Re: John_Kunkel]
#2566916
10/20/18 02:02 PM
10/20/18 02:02 PM
Posts: 1,696 central il.
second 70
central il.
I had used several different amp crimpers over the years as a lineman. Some have changeable dies others don't. The O is a common size used on most house service sleeves. We had sleeves from #6 to #1/0 that used the same die. I believe O is 5/8. They make what we call an O D tool that had 1 fixed opening O and one that take dies. Meaning fixed O and die’s. Also called a one shot. We found a couple that had a 9/16 fixed instead of the 5/8 too. Depending on who's sleeves your using you sometimes need a different die for the same size wire. Most new crimper's are either ratchet, hydraulic, battery-operated and insulated.
Those were dangerous on live wire with the long metal handles.
