Tool ID #2565461
10/17/18 05:16 PM
10/17/18 05:16 PM
Rio Linda, CA
John_Kunkel Offline OP
Rio Linda, CA
This crimper is stamped:
AMP Type O
16-14
59498
16-14 is likely the wire gauge but the jaws are about 3/8" diameter, a little big for that wire gauge.
Re: Tool ID [Re: John_Kunkel] #2565467
10/17/18 05:29 PM
10/17/18 05:29 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Maybe it's for O gage and 16-14 is the tool number. Or maybe it came with a diffent set of dies than what is currently installed.
Re: Tool ID [Re: John_Kunkel] #2565491
10/17/18 06:13 PM
10/17/18 06:13 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
You’re thinkIng electrical wire or steel rope?
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Tool ID [Re: FurryStump] #2565548
10/17/18 07:53 PM
10/17/18 07:53 PM
GomangoCuda Offline
GomangoCuda  Offline
Good point. Could very well be for steel ropè.
Re: Tool ID [Re: GomangoCuda] #2565551
10/17/18 07:58 PM
10/17/18 07:58 PM
Rio Linda, CA
Rio Linda, CA
The brand name AMP suggests electrical.
Re: Tool ID [Re: John_Kunkel] #2565554
10/17/18 08:03 PM
10/17/18 08:03 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I'm thinking it's got a different set of dies in it.
- Stu Harmon
Re: Tool ID [Re: John_Kunkel] #2565556
10/17/18 08:05 PM
10/17/18 08:05 PM
GomangoCuda Offline
GomangoCuda  Offline
Agree that Amp is very big in electrical connectors and crimpers. I think it was sold as a 16-14 crimper and has had the dies changed since then.
Re: Tool ID [Re: John_Kunkel] #2565559
10/17/18 08:06 PM
10/17/18 08:06 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Yep it is an Amp brand conductor terminal crimp tool. Should have different interchangeable dies for different size conductors.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Tool ID [Re: moparmarks] #2565575
10/17/18 08:42 PM
10/17/18 08:42 PM
Lakeland, FL
sixpakchallenger Offline
Lakeland, FL
The "O" die is for distribution electrical connectors, typically H-taps. Probably #1 stranded aluminum to #6 solid copper to feed a transformer.
2007 Mustang GT Vert
2004 Ram 2500 QC 4X4
1971 Challenger Vert 5.7 Hemi Project
Re: Tool ID [Re: John_Kunkel] #2566856
10/20/18 10:54 AM
10/20/18 10:54 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Possibly AWG Electrical wire. AWG # 0 (1/0) Diameter 0.3249”
Ron
Re: Tool ID [Re: John_Kunkel] #2566916
10/20/18 02:02 PM
10/20/18 02:02 PM
central il.
second 70 Offline
second 70  Offline
central il.
I had used several different amp crimpers over the years as a lineman. Some have changeable dies others don't.
The O is a common size used on most house service sleeves. We had sleeves from #6 to #1/0 that used the same die. I believe O is 5/8. They make what we call an O D tool that had 1 fixed opening O and one that take dies. Meaning fixed O and die’s. Also called a one shot. We found a couple that had a 9/16 fixed instead of the 5/8 too.
Depending on who's sleeves your using you sometimes need a different die for the same size wire.
Most new crimper's are either ratchet, hydraulic, battery-operated and insulated.
Those were dangerous on live wire with the long metal handles.
