Trying to figure out which springs for a 2" Lift on a 74 RC #2564420
10/15/18 02:48 PM
10/15/18 02:48 PM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
I've got a 74 Ramcharger, 440 truck; that I'm now putting D60/D70 axles under.
It's all original, and I'll be running 17x9 wheels with LT285/70r17's (33" tire)
My goals are to maintain current ride quality (it's not smooth, but it's NOT harsh either). if it's Harsh my wife (who owns the truck and wants to drive it on good weather days), won't drive it.
The front seems pretty straight forward, it's the rear that has me baffled. It has factory 4" blocks between the factory springs and axle.
Is it possible to find a set of springs, that won't be harsh, and will allow me to eliminate the factory block and still maintain the OE spring hangar locations?
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Trying to figure out which springs for a 2" Lift on a 74 RC [Re: shanker] #2564631
10/15/18 10:50 PM
10/15/18 10:50 PM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
Try it as is....you will gain height with the axle swap.
The larger axle tubes will get you close.
Ed
Re: Trying to figure out which springs for a 2" Lift on a 74 RC [Re: shanker] #2564716
10/16/18 03:20 AM
10/16/18 03:20 AM
ND
dodgedon Offline
dodgedon  Offline
ND
I wanted to add about 2" to my 85 Crew cab. What I did was use the soft ride spring from Sky Jacker on the front. I think they called it a 1.5-2.5 lift. A much better ride than what I had on the front.
For the rear I used the blocks from a 92 W250. These are 6" and used my original rear springs.
I know this isn't what you are asking, but its how i did mine.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: Trying to figure out which springs for a 2" Lift on a 74 RC [Re: dodgedon] #2565015
10/16/18 07:12 PM
10/16/18 07:12 PM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
so those softride springs rode good? They're on my short list for solutions for the front.
Re: Trying to figure out which springs for a 2" Lift on a 74 RC [Re: shanker] #2565050
10/16/18 08:24 PM
10/16/18 08:24 PM
Paducah, KY USA Earth
jcruse64 Offline
jcruse64  Offline
Shanker, I did the 4" system from Skyjacker, with the soft rides up front. This is on a '93 club cab 1/2 ton. The springs are a much improved ride from stock, with almost 4 years of use now.
Re: Trying to figure out which springs for a 2" Lift on a 74 RC [Re: shanker] #2565198
10/17/18 01:57 AM
10/17/18 01:57 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I've used the Skyjacker soft ride 4" springs on a couple trucks. Nicer ride than the stock ones but the rears won't carry a load like the originals. Being your is a Ramcharger that should be a problem.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, .
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Trying to figure out which springs for a 2" Lift on a 74 RC [Re: shanker] #2565721
10/18/18 12:21 AM
10/18/18 12:21 AM
ND
dodgedon Offline
dodgedon  Offline
ND
Yes, Like the other guys here are saying. They do ride better than the originals.
67 Charger 383 auto
