Re: SOURCES FOR CUSTOM DANA
[Re: A/MP]
#2531709
08/04/18 11:59 PM
08/04/18 11:59 PM
Posts: 4,669 Wichita
GY3
Wichita
Other than Moser or Strange, anyone doing custom length 60's in the PA/NJ/DE area. Why waste money on shipping if I can get it locally. Have you tried 4x4 and offroad shops near you?
[Re: A/MP]
#2531780
08/05/18 03:09 AM
08/05/18 03:09 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Pretty sure the good Doctor will put one together at whatever length you need, with whatever you want in it. http://www.doctordiff.com/strange-60.htmlEdit: just saw the local part.... nevermind, I guess.
[Re: A/MP]
#2531820
08/05/18 11:12 AM
08/05/18 11:12 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I did one locally, bought a truck housing and had it cut down and gears installed. I know I saved money but being able to make one show up with a few mouse clicks would have been nice.
68 Barracuda Formula S 340
[Re: J_BODY]
#2531823
08/05/18 11:19 AM
08/05/18 11:19 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
Use the S60 if starting from scratch. Side adjusters are sooooo much nicer The most truthful words ever spoken on a mopar site lol. Just finished a gear swap on my normal no side adjuster dana....
[Re: Bad340fish]
#2531826
08/05/18 11:38 AM
08/05/18 11:38 AM
GY3
Wichita
I did one locally, bought a truck housing and had it cut down and gears installed. I know I saved money but being able to make one show up with a few mouse clicks would have been nice. Thats what I did. Bought the stuff from Dr. Diff and took the full floater truck housing with all the parts to my local chassis shop. For under $400, they welded on the ends and installed/setup the ring and pinion.
[Re: A/MP]
#2531902
08/05/18 03:04 PM
08/05/18 03:04 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
look for Strange Engineering vendors in you area, most likely one of them can help you out STRANGE ENGINEERING<< Push here for dealer locator
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: A/MP]
#2531918
08/05/18 03:37 PM
08/05/18 03:37 PM
Posts: 11,531 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Strange builds very nice stuff. Talk to a dealer. They have freight to deal with as well and sales tax. But for an item like that, may be able to work with you as long as you don't try to beat them up for every dollar on the best unit you can buy. Plenty of shops in that area.
[Re: A/MP]
#2532038
08/05/18 08:48 PM
08/05/18 08:48 PM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
All else being equal, unless you perform most of the labor, you will rarely save money over the cost of a mail order Dana 60 assembly. Freight cost is also negligible, as the components must be shipped anyway. See below: http://www.doctordiff.com/strange-60.html
[Re: NoFrills]
#2532074
08/05/18 10:19 PM
08/05/18 10:19 PM
Posts: 1,269 Way out in the sticks of Weste...
DusterDog
There's a shop in Greensburg, PA called Greensburg Machine & Driveline.
The owner is a Mopar guy, has a Dodge pulling truck
The # is (724)837-8223, I think they're open from 8:00AM-5:00PM Mon-Fri
"I've upped my horsepower, so...... UP YOURS!!!"
[Re: A/MP]
#2532306
08/06/18 03:10 PM
08/06/18 03:10 PM
Posts: 604 TN
1DGEMAN
TN
You didn't say your application race or street. For race nothing beats Mark Williams. Strongest axles lightest components worth doing it only once the right way.
Real Men shift for themselves
[Re: A/MP]
#2532323
08/06/18 03:55 PM
08/06/18 03:55 PM
an8sec70cuda
I scored a couple of Dana 60 truck rears off craigslist for cheap. Bought some parts from Dr. Diff and used gearsets bought from members here. Have a friend that has the bearing cups, setup shaft, and jig to narrow the housings. Set them up myself...strong rear for cheap.
[Re: A/MP]
#2535836
08/13/18 08:47 PM
08/13/18 08:47 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I build one from a truck and used the Ford Torino ends...way more brake options...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
