SOURCES FOR CUSTOM DANA #2531677
08/04/18 11:02 PM
08/04/18 11:02 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Other than Moser or Strange, anyone doing custom length 60's in the PA/NJ/DE area. Why waste money on shipping if I can get it locally.
Re: SOURCES FOR CUSTOM DANA [Re: A/MP] #2531709
08/04/18 11:59 PM
08/04/18 11:59 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Have you tried 4x4 and offroad shops near you?
'63 Dodge 330
11.19 @ 121 mph
Re: SOURCES FOR CUSTOM DANA [Re: GY3] #2531720
08/05/18 12:28 AM
08/05/18 12:28 AM
birdtracker Offline
birdtracker  Offline
I know a guy here in Ohio, pm me if interested. Birdtracker
Re: SOURCES FOR CUSTOM DANA [Re: A/MP] #2531748
08/05/18 01:21 AM
08/05/18 01:21 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Use the S60 if starting from scratch. Side adjusters are sooooo much nicer
Re: SOURCES FOR CUSTOM DANA [Re: A/MP] #2531780
08/05/18 03:09 AM
08/05/18 03:09 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Pretty sure the good Doctor will put one together at whatever length you need, with whatever you want in it.
http://www.doctordiff.com/strange-60.html
Edit: just saw the local part.... nevermind, I guess.
Re: SOURCES FOR CUSTOM DANA [Re: A/MP] #2531785
08/05/18 04:19 AM
08/05/18 04:19 AM
I would check around with both Strange, Moser and any other company you trust, they do get a lot better shipping rate than we do on a one time deal scope twocents
Re: SOURCES FOR CUSTOM DANA [Re: A/MP] #2531820
08/05/18 11:12 AM
08/05/18 11:12 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I did one locally, bought a truck housing and had it cut down and gears installed. I know I saved money but being able to make one show up with a few mouse clicks would have been nice.
68 Barracuda Formula S 340
Re: SOURCES FOR CUSTOM DANA [Re: J_BODY] #2531823
08/05/18 11:19 AM
08/05/18 11:19 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The most truthful words ever spoken on a mopar site lol. Just finished a gear swap on my normal no side adjuster dana....
Re: SOURCES FOR CUSTOM DANA [Re: Bad340fish] #2531826
08/05/18 11:38 AM
08/05/18 11:38 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Thats what I did. Bought the stuff from Dr. Diff and took the full floater truck housing with all the parts to my local chassis shop. For under $400, they welded on the ends and installed/setup the ring and pinion.
'63 Dodge 330
11.19 @ 121 mph
Re: SOURCES FOR CUSTOM DANA [Re: A/MP] #2531902
08/05/18 03:04 PM
08/05/18 03:04 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
look for Strange Engineering vendors in you area, most likely one of them can help you out
STRANGE ENGINEERING<< Push here for dealer locator
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: SOURCES FOR CUSTOM DANA [Re: A/MP] #2531918
08/05/18 03:37 PM
08/05/18 03:37 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Strange builds very nice stuff. Talk to a dealer. They have freight to deal with as well and sales tax. But for an item like that, may be able to work with you as long as you don't try to beat them up for every dollar on the best unit you can buy. Plenty of shops in that area.
Re: SOURCES FOR CUSTOM DANA [Re: J_BODY] #2531996
08/05/18 07:27 PM
08/05/18 07:27 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
[quote=J_BODY]Use the S60 if starting from scratch. Side adjusters are sooooo much nicer [/qu4ote]
This for sure.
Re: SOURCES FOR CUSTOM DANA [Re: A/MP] #2532038
08/05/18 08:48 PM
08/05/18 08:48 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
All else being equal, unless you perform most of the labor, you will rarely save money over the cost of a mail order Dana 60 assembly.
Freight cost is also negligible, as the components must be shipped anyway.
See below:
Re: SOURCES FOR CUSTOM DANA [Re: DoctorDiff] #2532041
08/05/18 09:00 PM
08/05/18 09:00 PM
fullmetaljacket Offline
DR Diff will set it up in a jiffy. Shipping is the culprit.
Re: SOURCES FOR CUSTOM DANA [Re: fullmetaljacket] #2532072
08/05/18 10:12 PM
08/05/18 10:12 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
A&D JACKSON NJ
Re: SOURCES FOR CUSTOM DANA [Re: NoFrills] #2532074
08/05/18 10:19 PM
08/05/18 10:19 PM
Way out in the sticks of Weste...
DusterDog Offline
DusterDog  Offline
There's a shop in Greensburg, PA called Greensburg Machine & Driveline.
The owner is a Mopar guy, has a Dodge pulling truck
The # is (724)837-8223, I think they're open from 8:00AM-5:00PM Mon-Fri
"I've upped my horsepower, so...... UP YOURS!!!"
Re: SOURCES FOR CUSTOM DANA [Re: A/MP] #2532306
08/06/18 03:10 PM
08/06/18 03:10 PM
TN
1DGEMAN Online content
1DGEMAN  Online Content
TN
You didn't say your application race or street. For race nothing beats Mark Williams. Strongest axles lightest components worth doing it only once the right way.
Real Men shift for themselves
Re: SOURCES FOR CUSTOM DANA [Re: A/MP] #2532323
08/06/18 03:55 PM
08/06/18 03:55 PM
an8sec70cuda Offline
I scored a couple of Dana 60 truck rears off craigslist for cheap. Bought some parts from Dr. Diff and used gearsets bought from members here. Have a friend that has the bearing cups, setup shaft, and jig to narrow the housings. Set them up myself...strong rear for cheap.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: SOURCES FOR CUSTOM DANA [Re: A/MP] #2535836
08/13/18 08:47 PM
08/13/18 08:47 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I build one from a truck and used the Ford Torino ends...way more brake options...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
