New Wheel Vintiques rallye's don't go over hub
#2523684
07/18/18 05:28 PM
07/18/18 05:28 PM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
Just got my new 15 x 6 5on4 Rallye's from WV. They almost go on all the way. They can't go over the slight ridge on the disc brake hub. Do I have to sand the powdercoat alittle so it slides over? Hello RUST !
Still looking for LM29H1B415501, '71 Demon 340
Re: New Wheel Vintiques rallye's don't go over hub
[Re: PAULS_340]
#2523686
07/18/18 05:30 PM
07/18/18 05:30 PM
Posts: 13,573 md
mopars4ever
md
[Re: PAULS_340]
#2523758
07/18/18 07:28 PM
07/18/18 07:28 PM
Posts: 14,889 up yours
Supercuda
Just got my new 15 x 6 5on4 Rallye's from WV. They almost go on all the way. They can't go over the slight ridge on the disc brake hub. Do I have to sand the powdercoat alittle so it slides over? Hello RUST ! What is this on? I don't recall ever seeing a slight ridge on my rotors before.
[Re: PAULS_340]
#2523761
07/18/18 07:32 PM
07/18/18 07:32 PM
Posts: 13,573 md
mopars4ever
md
What is this on? I don't recall ever seeing a slight ridge on my rotors before. I have seen it on some aftermarket rotors but not on OEM.
[Re: mopars4ever]
#2523765
07/18/18 07:38 PM
07/18/18 07:38 PM
Supercuda
I wonder if the OP has a stock rim to test fit? Could narrow down if it's the rim or the rotor.
If it's the rim, I'd probably see if a machine shop would cut the rotor hub enough to fit?
[Re: cbusters]
#2523896
07/19/18 01:11 AM
07/19/18 01:11 AM
PAULS_340
Motown, Mi
I do have aftermarket rotors and it does have a very slight ridge. I thought maybe the powder-coating was causing it, but no. I ended up slowly bolting down each lugnut and pressfit the wheels on. Not fun getting them off.
[Re: PAULS_340]
#2524040
07/19/18 12:38 PM
07/19/18 12:38 PM
Posts: 8,393 Highland, MI.
Sunroofcuda
Highland, MI.
Center holes on OE wheels are 2-3/4".
[Re: PAULS_340]
#2524197
07/19/18 06:52 PM
07/19/18 06:52 PM
Posts: 4,793 Castlegar, BC, Canada
That AMC Guy
I had the same issue years back when I had my AMC Rallyes powder-coated. The coating is thicker than you realize. I had to take my dye-grinder and whittle the coating off the centers before the wheel would slip on easily.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: duster2]
#2527017
07/25/18 06:15 PM
07/25/18 06:15 PM
PAULS_340
Motown, Mi
That's what I did with the die grinder. Then sealed it. Went on perfectly.
