Re: story of wreck 2018 Dodge Demon
[Re: theraif]
#2526300
07/24/18 11:30 AM
07/24/18 11:30 AM
My big takeaway after watching the video is...... Mrs. Mush is pretty easy on the eyes As for the run itself, by watching the tach and listening to the audio it was clear to me the car was never really hooked up right from the start. Looks like he’s not going to let this incident keep him from going back....... be interesting to see what happens in the future with it.
[Re: theraif]
#2526348
07/24/18 12:50 PM
07/24/18 12:50 PM
an8sec70cuda
He's on the right track...ripped off one of those godawful fender flares.
[Re: an8sec70cuda]
#2526543
07/24/18 06:54 PM
07/24/18 06:54 PM
Posts: 3,095 Idaho
Runner
Idaho
He's on the right track...ripped off one of those godawful fender flares. i couldnt agree more
[Re: Runner]
#2526564
07/24/18 07:27 PM
07/24/18 07:27 PM
Posts: 20,160 PA.
pittsburghracer
I’ll take one of those cars with the ugly fender flairs if you are giving one away.
[Re: theraif]
#2526575
07/24/18 07:46 PM
07/24/18 07:46 PM
Silver70
Rust Belt, SW PA
I like the flares... Maybe I'll add some to my cuda
[Re: fast68plymouth]
#2526840
07/25/18 12:30 PM
07/25/18 12:30 PM
BradH
Persistence is a good trait, but it needs to be paired with the ability to learn from one's mistakes. I usually learn things the hard way, unfortunately, so one without the other is a recipe for self-inflicted .
[Re: BradH]
#2526877
07/25/18 01:38 PM
07/25/18 01:38 PM
Posts: 20,160 PA.
pittsburghracer
Been there done that but like I said before his pass should have been aborted long before he lost it. Broken oil line hit me on a quick 16 qualifying pass right before the 1/8 mile traps. Got it slowed from around 125 mph but when it touched the guardrail a fiberglass body strut went trough a new slick and with the short Daytona wheelbase put her on its roof. Slide about a 1/2 mile like a turtle after an ice storm.
[Re: theraif]
#2529086
07/30/18 03:34 PM
07/30/18 03:34 PM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I seen the vid back when it happend. And he has comment on it a few differnt times....one of his comments were. One rear tire was spinning twice the speed the front tires....and one rear tire was even spinning twice as fast as the opposite rear. How does that happen unless there was something wet/slick on the track
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#2529165
07/30/18 05:55 PM
07/30/18 05:55 PM
Posts: 1,845 Tampa
DusterDave
Tampa
The guy has a Demon, a Hellcat and a hot wife. No need to feel bad for him!
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: toplescuda]
#2529178
07/30/18 06:20 PM
07/30/18 06:20 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I seen the vid back when it happend. And he has comment on it a few differnt times....one of his comments were. One rear tire was spinning twice the speed the front tires....and one rear tire was even spinning twice as fast as the opposite rear. How does that happen unless there was something wet/slick on the track If you have 3 tires rolling at the same speed, the one without traction wont influence any directional change. Try a “one wheelie peely” with an open rear end. No sideways action. It would be a different story with a spool car and a broken axle. That will shoot you straight across the track. The declaration of double wheel speed on one side indicates that the car has a diff, and the car is not being propelled when that happens. Just watch “my cousin Vinnie”😀
[Re: DusterDave]
#2529244
07/30/18 09:06 PM
07/30/18 09:06 PM
Silver70
Rust Belt, SW PA
The guy has a Demon, a Hellcat and a hot wife. No need to feel bad for him! Not only that, this is a fairly easy to replace car if it had came to that... it's not like it was some project he spent countless hours building.
[Re: theraif]
#2529298
07/30/18 10:35 PM
07/30/18 10:35 PM
Poking around the net I see a Hennessy Demon went 9.14@152. The race to the 8’s is on.
