Hood pin lanyard lengths - help with definitive list
#2509726
06/17/18 08:33 PM
06/17/18 08:33 PM
Posts: 12,422 Warren, MI
71TA
Warren, MI
There doesn't appear to be any definitive list online.
What I've found so far. And I'm sure this list is basically the cars that actually CAME with hood pins. For example I'm sure the 13" lanyards would fit all Duster and Dart Sports to 76.
6" black rubber coated - For 69-1/2" A12 lift-off hood cars. Important Notes: The rivets in the hood pin bezels are at 12, 3, 6 and 9 o'clock as you look at any given bezel from the front of the hood. All the lanyards are on the inside rivets.
13" 70-72(76) Duster, 71-72 Scamp (13" Duster factory lanyard length verified)
18" 70-74 Challenger (assuming TA also), 70-72 (76) Dart, 71-72 Demon? 69 Daytona (per Moparts member Daytona) 3586156 - TA Hood pin kit
23" 70-74 Barracuda (assuming AAR also), 70 B Bodies, 70 Superbird (per Moparts member DAYCLONA)
25" 68-69 & 71-74 B Bodies
Re: Hood pin lanyard lengths - help with definitive list
[Re: 71TA]
#2509729
06/17/18 08:42 PM
06/17/18 08:42 PM
Posts: 18,157 Mass
DAYCLONA
Mass
69 Daytona, 70 Superbird
Superbird - saw some online info where there was some dispute over 23 or 25" lanyards. 23" is the "norm" for the wingcars, 25" is what the aftermarket has assigned to them... But to add even more pot stirring, here's an early road test photo from back in the day of a 69 Daytona hoodpin lanyard...
[Re: 71TA]
#2509809
06/18/18 12:34 AM
06/18/18 12:34 AM
Posts: 2,331 Banana Republic
FM3AAR
Banana Republic
Interesting thread. Being curious, I went out and measured the AAR and I came up with 26" eyelet to eyelet. They look ancient but I guess they got changed at some point in the 70's?
“You’ll own nothing” — And “you’ll be happy about it.” K. Schwab
[Re: burdar]
#2510339
06/19/18 12:02 PM
06/19/18 12:02 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Hood pins were only available on E-bodies in 70-71. G-series option report says 795 1971 Plymouth GTX's left the factory with hood pins installed... Or a little over 29% of production...
[Re: RSNOMO]
#2510390
06/19/18 02:22 PM
06/19/18 02:22 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Hood pins were only available on E-bodies in 70-71. G-series option report says 795 1971 Plymouth GTX's left the factory with hood pins installed... Or a little over 29% of production... Burdar was disqualifying 72-4 E bodies from the list... not "other" models
[Re: 71TA]
#2510410
06/19/18 03:17 PM
06/19/18 03:17 PM
Posts: 7,365 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Burdar was disqualifying 72-4 E bodies from the list... not "other" models Correct. No hood pins on 72-74 E-bodies.
[Re: RSNOMO]
#2510520
06/19/18 09:01 PM
06/19/18 09:01 PM
Posts: 1,893 Harriman NY
71GTX471
Harriman NY
Hood pins were only available on E-bodies in 70-71. G-series option report says 795 1971 Plymouth GTX's left the factory with hood pins installed... Or a little over 29% of production... And mine is one of them.
