There doesn't appear to be any definitive list online.
What I've found so far. And I'm sure this list is basically the cars that actually CAME with hood pins. For example I'm sure the 13" lanyards would fit all Duster and Dart Sports to 76.
6" black rubber coated - For 69-1/2" A12 lift-off hood cars.
Important Notes: The rivets in the hood pin bezels are at 12, 3, 6 and 9 o'clock as you look at any given bezel from the front of the hood. All the lanyards are on the inside rivets.
13" 70-72(76) Duster, 71-72 Scamp
(13" Duster factory lanyard length verified)
18" 70-74 Challenger (assuming TA also), 70-72 (76) Dart, 71-72 Demon? 69 Daytona (per Moparts member Daytona)
3586156 - TA Hood pin kit
23" 70-74 Barracuda (assuming AAR also), 70 B Bodies, 70 Superbird (per Moparts member DAYCLONA)
25" 68-69 & 71-74 B Bodies
