mopar performance roller rockers #2499349
05/23/18 06:52 AM
05/23/18 06:52 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
hi has any one ran these blue mp 1.6 rr with a solid roller cam on a sb 7500 rpm 240 seat 700lbs open will they last in a speedway deal ?
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: mopar performance roller rockers [Re: Ian] #2499363
05/23/18 09:14 AM
05/23/18 09:14 AM
Saskatchewan (SK)
79410aspenrt Offline
Saskatchewan (SK)
yes i have. even higher rpm then you are going to spin. 8600 rpm for many many years.
Re: mopar performance roller rockers [Re: Ian] #2499406
05/23/18 11:28 AM
05/23/18 11:28 AM
Tulsa, Oklahoma
340Cuda Online content
340Cuda  Online Content
Tulsa, Oklahoma
I have never considered them because of the they had no bearings or bushings, direct contact on the shaft.
However it sounds like in 79410aspenrt's case that has not been an issue.
Re: mopar performance roller rockers [Re: 340Cuda] #2499470
05/23/18 01:44 PM
05/23/18 01:44 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Quick answer:
Yes
Re: mopar performance roller rockers [Re: Biginchmopar] #2499471
05/23/18 01:45 PM
05/23/18 01:45 PM
Carson City, Nevada
Carson City, Nevada
NO!
Re: mopar performance roller rockers [Re: Biginchmopar] #2499476
05/23/18 01:47 PM
05/23/18 01:47 PM
Carson City, Nevada
Carson City, Nevada
On another note, all Mopar Blue rockers, if they are the good ones, haven't been blue for a lot of years.
Re: mopar performance roller rockers [Re: Biginchmopar] #2499538
05/23/18 04:11 PM
05/23/18 04:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I ran them on my SB for about 1 year.. shifted
at 8200 rpm.. I bought a set of TD so I swapped
them out.. I still have them on 1 of my back-up
engines... mine are on a set of ported W-2s
wave
Re: mopar performance roller rockers [Re: Biginchmopar] #2499679
05/23/18 09:13 PM
05/23/18 09:13 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
Originally Posted By Biginchmopar
NO!
they are the std ones for j heads what would you go for then
Re: mopar performance roller rockers [Re: Ian] #2499686
05/23/18 09:39 PM
05/23/18 09:39 PM
Carson City, Nevada
Carson City, Nevada
NO!
Well it comes down to what you can afford.
1.) T&D (buy them once and never look back)
2.) Harland Sharp (expensive in my opinion)
3.) Hughes (best for money spent)
4.) Crane
Re: mopar performance roller rockers [Re: Biginchmopar] #2499766
05/24/18 12:09 AM
05/24/18 12:09 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Getting replacements would be the biggest concern. The Blue Mopar rockers are made by Crane, not sure Crane still makes the offset arms these days.
If they are going to replace them, I'd go with a system with a bearing, like the T&D paired shaft deal.
Alan Jones
Re: mopar performance roller rockers [Re: Ian] #2499785
05/24/18 12:51 AM
05/24/18 12:51 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
its a burn out car alan 318 aeroflow heads i build the auto for it ,it cops a hard time it has a ft hyd atm but would like to rev it to 7500 rpm with a solid roller here is a vid of what it does it hard on things like a speedway car https://www.youtube.com/watch?v=UCW0asOTYag
Re: mopar performance roller rockers [Re: Ian] #2499832
05/24/18 02:58 AM
05/24/18 02:58 AM
LA360 Offline
LA360  Offline
Sorry, I've got W2 rockers on the brain at the moment, so excuse my last post.
Put a full roller rocker in it to be on the safe side. Something like the Crane style, I'd be checking them after each event. Once the roller goes in, it will be sitting on 7K plus. Don't skimp on the push rods either
Alan Jones
Re: mopar performance roller rockers [Re: Ian] #2499964
05/24/18 01:30 PM
05/24/18 01:30 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Crane is not making any aluminum shaft rockers for small blocks ...straight or offset...
Tony
70 AARCuda Vitamin C
71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield)
71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas)
71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: mopar performance roller rockers [Re: 70AARcuda] #2505527
06/07/18 11:06 AM
06/07/18 11:06 AM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
Crane hasn't made any MoPar shaft mount aluminum rockers (either gold or blue) for over a decade. Not sure where the blue ones are currently coming from. Ductile iron adjustable shaft mount rockers are offered, in 1.5 and 1.5 ratios for LA and B/RB applications. Regards, Chase
