FMJ Brake Booster in a B-Body?
#2497545
05/18/18 01:58 PM
05/18/18 01:58 PM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
I still know where there are a number of FMJ cars in a junkyard. I was wondering if there would be a fit up issue with a brake booster sourced from one of these cars on my 1972 B-Body?
No longer taking $h!t from anyone!
Re: FMJ Brake Booster in a B-Body?
[Re: DUFFMAN]
#2497608
05/18/18 05:25 PM
05/18/18 05:25 PM
Posts: 1,500 Bradenton, Fl 34203
Kilroy was here
Bradenton, Fl 34203
If you're looking for a cost effective way, I put an Advance Auto booster on mine, works fine. 70 B body. Price was reasonable.
[Re: BDW]
#2497660
05/18/18 07:44 PM
05/18/18 07:44 PM
DUFFMAN
Slantytown
I can't image a 40 yr. booster from JY would be good. As mentioned, go to RockAuto or local parts store and get one. I was thinking that after I posted this. However, even a rebuilt FMJ booster is more reasonably priced than one for a 1972 B-body. Also, since I don't have a core to exchange, the core charge is much lower. So it still would be advantageous to use the newer booster if it will fit.
[Re: moparx]
#2497854
05/19/18 01:01 PM
05/19/18 01:01 PM
Posts: 4,405 Michigan
MarkZ
Worthy
Worthy
keep in mind the diameter of the FMJ booster doesn't interfere with the hood closing. it may be close on some applications. It'll certainly hit the valve cover if a big block is in the car. All F/M/J boosters are two bolt master cylinders. When I did the BB swap in my car I was able to source a booster from a late 70's (something with a big block, forget) and it was the smaller diameter kind. Only ran me $50.
[Re: DUFFMAN]
#2497928
05/19/18 06:07 PM
05/19/18 06:07 PM
Posts: 13,573 md
mopars4ever
md
All F/M/J boosters are two bolt master cylinders. 76 and 77 F body is 4 bolt master cyl. Even so I still think there is a difference between the 72 b body and the F body boosters.
[Re: Joe12459]
#2498147
05/20/18 10:48 AM
05/20/18 10:48 AM
DUFFMAN
Slantytown
I put an FMJ booster/master cylinder in my 72 big block RR. Fits right in, no mods. Awesome. Thank you! On more question. Is there a reinforcement plate between the booster and the firewall? If there is then I will probably have to source that from a junkyard.
[Re: DUFFMAN]
#2498197
05/20/18 01:17 PM
05/20/18 01:17 PM
Posts: 19,355 north of coder
moparx
duffer, glad the news is good for ya ! i remember using a late 70, early 80 ish booster, M or J, i can't remember which, on my 64 belvedere post car which required a slight ovaling of the original firewall through hole, and drilling a couple of extra mounting holes, and if i remember correctly, there was a stiffening plate, but that was way back in the late 80's, early 90's, so don't take that as gospel. my brain is loosing memory space. the car had a poly motor, and there were no clearance issues at all with the big diameter booster.
[Re: moparx]
#2498380
05/20/18 09:19 PM
05/20/18 09:19 PM
DUFFMAN
Slantytown
duffer, glad the news is good for ya ! i remember using a late 70, early 80 ish booster, M or J, i can't remember which, on my 64 belvedere post car which required a slight ovaling of the original firewall through hole, and drilling a couple of extra mounting holes, and if i remember correctly, there was a stiffening plate, but that was way back in the late 80's, early 90's, so don't take that as gospel. my brain is loosing memory space. the car had a poly motor, and there were no clearance issues at all with the big diameter booster. After almost 3 years I've got my Coronet back out of storage and I'm tinkering with it again which is been very therapeutic. However, I have 2 teenage kids and their activities, especially during the summer, can get expensive. This is why I'm looking for inexpensive ways to do upgrades.
