FMJ Brake Booster in a B-Body? #2497545
05/18/18 01:58 PM
05/18/18 01:58 PM
Slantytown
DUFFMAN Offline OP
Ask And Ye Shall Receive
DUFFMAN  Offline OP
Slantytown
I still know where there are a number of FMJ cars in a junkyard. I was wondering if there would be a fit up issue with a brake booster sourced from one of these cars on my 1972 B-Body?
No longer taking $h!t from anyone!
Re: FMJ Brake Booster in a B-Body? [Re: DUFFMAN] #2497608
05/18/18 05:25 PM
05/18/18 05:25 PM
Bradenton, Fl 34203
Kilroy was here Offline
Bradenton, Fl 34203
If you're looking for a cost effective way, I put an Advance Auto booster on mine, works fine. 70 B body. Price was reasonable.
Re: FMJ Brake Booster in a B-Body? [Re: DUFFMAN] #2497614
05/18/18 05:33 PM
05/18/18 05:33 PM
BDW Offline
BDW  Offline
I can't image a 40 yr. booster from JY would be good.
As mentioned, go to RockAuto or local parts store and get one.
Re: FMJ Brake Booster in a B-Body? [Re: BDW] #2497660
05/18/18 07:44 PM
05/18/18 07:44 PM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
I was thinking that after I posted this. However, even a rebuilt FMJ booster is more reasonably priced than one for a 1972 B-body. Also, since I don't have a core to exchange, the core charge is much lower. So it still would be advantageous to use the newer booster if it will fit.
Re: FMJ Brake Booster in a B-Body? [Re: DUFFMAN] #2497664
05/18/18 07:56 PM
05/18/18 07:56 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Double check the size of the bolt pattern on the firewall. I wont to say the FJM one is different, but its been quite a while since I worked on one.
Re: FMJ Brake Booster in a B-Body? [Re: TC@HP2] #2497831
05/19/18 12:12 PM
05/19/18 12:12 PM
moparx Offline
moparx  Offline
keep in mind the diameter of the FMJ booster doesn't interfere with the hood closing. it may be close on some applications.
beer
Re: FMJ Brake Booster in a B-Body? [Re: moparx] #2497854
05/19/18 01:01 PM
05/19/18 01:01 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
beer
It'll certainly hit the valve cover if a big block is in the car. All F/M/J boosters are two bolt master cylinders. When I did the BB swap in my car I was able to source a booster from a late 70's (something with a big block, forget) and it was the smaller diameter kind. Only ran me $50.
Re: FMJ Brake Booster in a B-Body? [Re: DUFFMAN] #2497928
05/19/18 06:07 PM
05/19/18 06:07 PM
md
mopars4ever Offline
mopars4ever  Offline
md
76 and 77 F body is 4 bolt master cyl. Even so I still think there is a difference between the 72 b body and the F body boosters.
Re: FMJ Brake Booster in a B-Body? [Re: DUFFMAN] #2498001
05/19/18 09:33 PM
05/19/18 09:33 PM
Catskill Mountains, NY
Joe12459 Offline
Joe12459  Offline
I put an FMJ booster/master cylinder in my 72 big block RR. Fits right in, no mods.
Re: FMJ Brake Booster in a B-Body? [Re: DUFFMAN] #2498071
05/20/18 12:15 AM
05/20/18 12:15 AM
md
mopars4ever Offline
mopars4ever  Offline
md
There is your answer thumbs
Re: FMJ Brake Booster in a B-Body? [Re: Joe12459] #2498147
05/20/18 10:48 AM
05/20/18 10:48 AM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
Awesome. Thank you!
On more question. Is there a reinforcement plate between the booster and the firewall? If there is then I will probably have to source that from a junkyard.
Re: FMJ Brake Booster in a B-Body? [Re: DUFFMAN] #2498197
05/20/18 01:17 PM
05/20/18 01:17 PM
moparx Offline
moparx  Offline
duffer, glad the news is good for ya ! i remember using a late 70, early 80 ish booster, M or J, i can't remember which, on my 64 belvedere post car which required a slight ovaling of the original firewall through hole, and drilling a couple of extra mounting holes, and if i remember correctly, there was a stiffening plate, but that was way back in the late 80's, early 90's, so don't take that as gospel. my brain is loosing memory space. the car had a poly motor, and there were no clearance issues at all with the big diameter booster.
beer
Re: FMJ Brake Booster in a B-Body? [Re: DUFFMAN] #2498238
05/20/18 02:24 PM
05/20/18 02:24 PM
md
mopars4ever Offline
mopars4ever  Offline
md
IIRC, My 73 charger had a plate that the booster mounted to.
Re: FMJ Brake Booster in a B-Body? [Re: moparx] #2498380
05/20/18 09:19 PM
05/20/18 09:19 PM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
beer
After almost 3 years I've got my Coronet back out of storage and I'm tinkering with it again which is been very therapeutic. However, I have 2 teenage kids and their activities, especially during the summer, can get expensive. This is why I'm looking for inexpensive ways to do upgrades.
Re: FMJ Brake Booster in a B-Body? [Re: DUFFMAN] #2498473
05/21/18 12:55 AM
05/21/18 12:55 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
when I had to replace the booster in my 78 Fury, I gave up one from a Volare as the core.... looked them up, same part number.... holding them side X side they were identical.
