Re: rear wheels (rear end) - harder to turn in reverse?
[Re: Exit1965]
#2494998
05/12/18 04:34 AM
05/12/18 04:34 AM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Probably the brakes dragging.
[Re: Exit1965]
#2495003
05/12/18 07:39 AM
05/12/18 07:39 AM
Posts: 5,777 ohio
ruderunner
ohio
Due to the cut of the ring and pinion yes it will be harder to turn in reverse than forward
Angry white pureblood male
[Re: CSK]
#2495231
05/12/18 08:15 PM
05/12/18 08:15 PM
Probably the brakes dragging. Pray that it is that!
