rear wheels (rear end) - harder to turn in reverse? #2494996
05/12/18 04:14 AM
05/12/18 04:14 AM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
I had the back of my Dart up in the air with the driveshaft out. It has a 742 case with suregrip. I noticed the wheels turn easily going forward, but when turning them backwards/reverse, it's quite a bit harder to turn.
Is that normal?
Re: rear wheels (rear end) - harder to turn in reverse? [Re: Exit1965] #2494998
05/12/18 04:34 AM
05/12/18 04:34 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Probably the brakes dragging.
Re: rear wheels (rear end) - harder to turn in reverse? [Re: Exit1965] #2495003
05/12/18 07:39 AM
05/12/18 07:39 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Due to the cut of the ring and pinion yes it will be harder to turn in reverse than forward
Angry white pureblood male
Re: rear wheels (rear end) - harder to turn in reverse? [Re: Exit1965] #2495010
05/12/18 09:12 AM
05/12/18 09:12 AM
A727Tflite Online content
A727Tflite  Online Content
If it's an automatic trans that's normal - you are turning partsbthat you normally wouldn't turn going in the normal direction. Next time you have an auto on the bench try turning the output shaft both directions and see what you feel.
Re: rear wheels (rear end) - harder to turn in reverse? [Re: Exit1965] #2495100
05/12/18 02:13 PM
05/12/18 02:13 PM
Me thinks you may have a problem, I don't remember any of my cars having the same problems your having now with the drive shaft gone confused work shruggy
Re: rear wheels (rear end) - harder to turn in reverse? [Re: Exit1965] #2495173
05/12/18 04:53 PM
05/12/18 04:53 PM
Opps, missed the part about the driveshaft out and being hard to turn. eek
Re: rear wheels (rear end) - harder to turn in reverse? [Re: CSK] #2495231
05/12/18 08:15 PM
05/12/18 08:15 PM
Pray that it is that!
Re: rear wheels (rear end) - harder to turn in reverse? [Re: Exit1965] #2495294
05/12/18 10:02 PM
05/12/18 10:02 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
I think the pinion nut has loosened (again).
Re: rear wheels (rear end) - harder to turn in reverse? [Re: Exit1965] #2498482
05/21/18 01:19 AM
05/21/18 01:19 AM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Yep, the pinon nut had loosened. I put a new nut (a "stover" nut) back on tight and now the wheels spin freely forward and backwards.
