Re: Taking paint off Lexan?
[Re: slantzilla]
#2475604
04/01/18 09:19 PM
04/01/18 09:19 PM
Posts: 43,127 Bend,OR USA
I was told by a house painter years ago to use always denatured alcohol on any paint that I wanted to clean up, same on decal glue Soak a rag really well and hold it on the paint long enough(2 to 5 minutes in some cases ) to try and soak it all the way through before seeing if the paint gets soggy enough to slide off easily Good luck
[Re: DoubleD]
#2476248
04/02/18 07:05 PM
04/02/18 07:05 PM
Posts: 252 southeast ky
mills.mopar
southeast ky
How about just changing your name to Mike? Might be easier.
If you love it lube it
68 dart 37 dodge coupe 71 challenger
[Re: mills.mopar]
#2476593
04/03/18 01:16 AM
04/03/18 01:16 AM
Posts: 20,171 Park Forest, IL
slantzilla
Park Forest, IL
How about just changing your name to Mike? Might be easier. My middle name is Mike, unfortunately his last name is on it too.
[Re: 451Mopar]
#2522408
07/16/18 04:44 AM
07/16/18 04:44 AM
slantzilla
Park Forest, IL
Looks nice. Not sure if it would have worked, but I have used HOPPS #9 on plastics to remove paint and stickers and it worked good. According to the MSDS:
SECTION 3 - COMPOSITION / INFORMATION ON INGREDIENTS ID INGREDIENT CAS NUMBER EINECS INDEX NUMBER % WT 1 Ethyl Alcohol 0000064-17-5 200-578-6 603-002-00-5 15 - 40 2 Kerosene 0008008-20-6 232-366-4 649-404-00-4 15 - 40 3 Oleic Acid 0000112-80-1 204-007-1 4 Amyl Acetate 0000628-63-7 211-047-3 607-130-00-2 5 - 10 5 Ammonium Hydroxide 0001336-21-6 215-647-6 007-001-01-2 1 - 5 I have some of that laying around. Never would have thought of it in a million years.
