Taking paint off Lexan? #2475569
04/01/18 08:27 PM
04/01/18 08:27 PM
Park Forest, IL
slantzilla Offline OP
Park Forest, IL
Is there any good way to do it without ruining the Lexan? Mike wanted his name off the car, no problem as pretty much everything else is vinyl. Nope, name is paint. nervous
Thanks! wave
Re: Taking paint off Lexan? [Re: slantzilla] #2475604
04/01/18 09:19 PM
04/01/18 09:19 PM
I was told by a house painter years ago to use always denatured alcohol on any paint that I wanted to clean up, same on decal glue up
Soak a rag really well and hold it on the paint long enough(2 to 5 minutes in some cases shruggy) to try and soak it all the way through before seeing if the paint gets soggy enough to slide off easily scope
Good luck up
Re: Taking paint off Lexan? [Re: slantzilla] #2475618
04/01/18 09:49 PM
04/01/18 09:49 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
if its hand lettered all jokes aside - easy off oven cleaner will take it off - lexan itself can actually be wet sanded and polished like paint - but is a time consuming process. I had a buddy who painted airplane and he got over-spray on the windows - we sanded and buffed that thing until the windows look like new
Re: Taking paint off Lexan? [Re: slantzilla] #2475656
04/01/18 11:17 PM
04/01/18 11:17 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Lexan, although a poly carbonate, has a special hardening on the surface to reduce scratching. Try something like Goof off as it removes oil and acrylic paints. 1 877 466 3633. As per anything try a test sample first
Re: Taking paint off Lexan? [Re: slantzilla] #2475704
04/02/18 12:17 AM
04/02/18 12:17 AM
Park Forest, IL
Park Forest, IL
Thanks guys! boogie
Re: Taking paint off Lexan? [Re: slantzilla] #2476072
04/02/18 01:37 PM
04/02/18 01:37 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
lexan with the coating is actually branded Marguard - if its not marguard - then it is straight up polycarbonate - AKA - lexan
Re: Taking paint off Lexan? [Re: DoubleD] #2476248
04/02/18 07:05 PM
04/02/18 07:05 PM
southeast ky
mills.mopar Offline
mills.mopar  Offline
southeast ky
How about just changing your name to Mike? Might be easier.
If you love it lube it
68 dart
37 dodge coupe
71 challenger
Re: Taking paint off Lexan? [Re: mills.mopar] #2476593
04/03/18 01:16 AM
04/03/18 01:16 AM
Park Forest, IL
Park Forest, IL
My middle name is Mike, unfortunately his last name is on it too. fart
Re: Taking paint off Lexan? [Re: slantzilla] #2476599
04/03/18 01:34 AM
04/03/18 01:34 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
[Klean Strip] from home depot or lowes. works great. Ok, not sure how safe it is on Lexon, but its fine with Polyurethane surfaces, so you might be safe. Try a small spot first. Works in like 30 seconds and is done in 15 minutes.
Re: Taking paint off Lexan? [Re: slantzilla] #2521883
07/14/18 05:11 PM
07/14/18 05:11 PM
Park Forest, IL
Park Forest, IL
Just to follow up, I tried scraping it off with a razor blade today. It kinda worked, but I saw I was putting fine scratches on the Lexan. I decided to try some headlight restoration polish I had and used a powerball in a drill. Worked great, and even took out the scratches I put in. boogie
Re: Taking paint off Lexan? [Re: slantzilla] #2522054
07/15/18 10:26 AM
07/15/18 10:26 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Nice job!! Now I need pics of the whole car.
Re: Taking paint off Lexan? [Re: dustergirl340] #2522109
07/15/18 01:17 PM
07/15/18 01:17 PM
Park Forest, IL
Park Forest, IL
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2498485/1.html
wave
Re: Taking paint off Lexan? [Re: slantzilla] #2522400
07/16/18 03:03 AM
07/16/18 03:03 AM
Thanks for the help bow up
Re: Taking paint off Lexan? [Re: slantzilla] #2522403
07/16/18 03:23 AM
07/16/18 03:23 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Looks nice. Not sure if it would have worked, but I have used HOPPS #9 on plastics to remove paint and stickers and it worked good. According to the MSDS:
SECTION 3 - COMPOSITION / INFORMATION ON INGREDIENTS
ID INGREDIENT CAS NUMBER EINECS INDEX NUMBER % WT
1 Ethyl Alcohol 0000064-17-5 200-578-6 603-002-00-5 15 - 40
2 Kerosene 0008008-20-6 232-366-4 649-404-00-4 15 - 40
3 Oleic Acid 0000112-80-1 204-007-1
4 Amyl Acetate 0000628-63-7 211-047-3 607-130-00-2 5 - 10
5 Ammonium Hydroxide 0001336-21-6 215-647-6 007-001-01-2 1 - 5
Re: Taking paint off Lexan? [Re: Cab_Burge] #2522407
07/16/18 04:42 AM
07/16/18 04:42 AM
Park Forest, IL
Park Forest, IL
You are welcome Sir. wave
Re: Taking paint off Lexan? [Re: 451Mopar] #2522408
07/16/18 04:44 AM
07/16/18 04:44 AM
Park Forest, IL
Park Forest, IL
I have some of that laying around. Never would have thought of it in a million years. shock
Re: Taking paint off Lexan? [Re: slantzilla] #2522424
07/16/18 09:12 AM
07/16/18 09:12 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
try rubbing compound
Re: Taking paint off Lexan? [Re: dustergirl340] #2522459
07/16/18 10:35 AM
07/16/18 10:35 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
iagree
