Any difference betweeb firecore and msd distributors #2466298
03/14/18 11:52 AM
03/14/18 11:52 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Need to pick out a distr. and ignition. Been planning on all msd, w/6AL-2. Low deck race only application. MSD seems to be the standard, pricey though. If I can save $500 and see no difference on the dyno, I'll consider firecore dist. and coil. I will use the 6AL-2 in either case. thanks
Re: Any difference betweeb firecore and msd distributors [Re: varunner] #2466318
03/14/18 12:44 PM
03/14/18 12:44 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I run a Firecore distributor with a 6AL and Blaster SS coil with Firecore wires and I have been very pleased with that system. I like the small diameter body and you can use them with any cylinder heads.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Any difference betweeb firecore and msd distributors [Re: varunner] #2466323
03/14/18 01:04 PM
03/14/18 01:04 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Where are you buying parts? You can buy the MSD distributor and Blaster II coil for $380 shipped.
Re: Any difference betweeb firecore and msd distributors [Re: varunner] #2466349
03/14/18 01:33 PM
03/14/18 01:33 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Any difference betweeb firecore and msd distributors [Re: varunner] #2466352
03/14/18 01:39 PM
03/14/18 01:39 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
Yeah the difference is that the MSD will actually hold together after 6 months of racing
Re: Any difference betweeb firecore and msd distributors [Re: varunner] #2466388
03/14/18 02:41 PM
03/14/18 02:41 PM
I like and use the MSD bigger gold colored race boxes with the proper coils, not any of the 6 series, on all of my race cars with compression and rev above 6000 RPM work
Their is a world of difference on how much spark the race boxes will make and how high they will do that at or above 7000 RPM work scope
I do buy and use used MSD7,7A,7C 7AL2 and 7AL3 with the proper coils, they will knock your socks off though so be careful around them thumbs
The first one I bought was a MSD 404B back in 1975, that box made my NHRA legal 426 Street Hemi motor start and idle a lot easier when cold and it would pull a lot harder in the summer in L.A. in the summer smog back then than the other two non MSD boxes I had used before then work
IHTHs thumbs
I do have two new MSD boxes that I haven't used yet, a Grid and a Digital 7 non programmable realcrazy shruggy
Re: Any difference betweeb firecore and msd distributors [Re: varunner] #2466397
03/14/18 02:50 PM
03/14/18 02:50 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Ok, the $500 saving is more like a couple hundred. msd prices are summit pro shop. Im sure the msd distrib. and 7AL box is the best combo. Just trying to save a buck where I can without hurting performance too much.
Re: Any difference betweeb firecore and msd distributors [Re: varunner] #2466442
03/14/18 04:01 PM
03/14/18 04:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
FWIW I've been running the same 6200 box under my dash for 15+ years not even a chip in it and go mid 9's........... beer
