Re: best intake for mild street 383? [Re: OhioMopar] #2435702
01/16/18 03:36 PM
01/16/18 03:36 PM
upstate NY 12839
TMBOOTS Offline
TMBOOTS  Offline
upstate NY 12839
I'm using the DP4B on my 68 383 Dart , 4-speed and really like the low/mid range pull..Prior intake was the RPM performer and that performed well at high RPMs.. DP4B gave me better hood clearance along with better street light acceleration..
Re: best intake for mild street 383? [Re: OhioMopar] #2436186
01/17/18 10:15 AM
01/17/18 10:15 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted By OhioMopar
Originally Posted By bee1971
Read / Click On Link Above
383 Intake Manifold Comparison
#2205968 ..... {1963 thru 1967 Casting} .................... 14.17 ..... 98.04
#2951666-1 .. {late-1970 and 1971 Casting} .............. 14.06 ..... 99.43
#2806301 .... {1968 and 1969 Casting} ...................... 14.04 ..... 99.11
Edelbrock Performer {#2186} .................................... 14.01 ..... 99.58
Mopar M1 Dual-Plane {#4529117} ............................. 13.99 ..... 100.02
Weiand Action Plus {#8008} ...................................... 13.97 ..... 99.78
Edelbrock {DP-4B} ................................................... 13.93 ..... 100.12
Why no Performer RPM?
Here is what this data suggests to me. The first small 4 bbl intake may have down 5 to 10hp over the others. All the rest are the same. The slight differences are mostly weather conditions, and maybe driver consistency and tune. For what it is, it is making nice power and is a well balanced package IMO.
Its a 280 to 300 hp deal and the cam and/or carb are the power limiting factors, not the intake. Same testing on a 350 or 375 hp deal and you'll see some performance separation between manifolds.
Re: best intake for mild street 383? [Re: orange elephants] #2436459
01/17/18 06:07 PM
01/17/18 06:07 PM
fast68plymouth Offline
My first thought was....... How mild is "mild"?
That could be anywhere from 300-425hp and still be relatively mild.
For the lower end of that range I'd go with a std performer, the higher end..... The RPM.
That assumes the rest of the car is built to be compatible with the overall character of the motor.
