Re: Upgrades?
[Re: humpty]
#2436275
01/17/18 01:07 PM
01/17/18 01:07 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
- Airbox - Dominator - Vacuum pump - If you’re ambitious gapless top rings
It already has an air pan that is sealed to the hood, low tension but not gapless rings. When it's time to rebuild if Brett will work on my manifold I'll see about going to a Dominator. It currently has a BX4 main body that is supposed to flow around 1050.
Re: Upgrades?
[Re: justinp61]
#2436700
01/18/18 02:34 AM
01/18/18 02:34 AM
Posts: 43,127 Bend,OR USA
What amp rating is this one rated at? It looks a lot like the little Mr. Gasket and Moroso switches If it is rated below 150 Amps momentary I wouldn't use it
Re: Upgrades?
[Re: justinp61]
#2436759
01/18/18 11:10 AM
01/18/18 11:10 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I have a switch from Longacre that has four poles. I use the two small poles to kill the continuous duty relay I have on the alternator output. My wire goes from ignition hot, through the kill switch, to the solenoid.
I am sure the Longacre switch is just a heavy duty industrial switch in thier packaging but it was fair priced and does exactly what I need it to.
68 Barracuda Formula S 340
Re: Upgrades?
[Re: Cab_Burge]
#2436781
01/18/18 12:13 PM
01/18/18 12:13 PM
justinp61
W. Kentucky
What amp rating is this one rated at? It looks a lot like the little Mr. Gasket and Moroso switches If it is rated below 150 Amps momentary I wouldn't use it 250 amp continuous and 2500 peak. After I posted the link I was looking at Jegs and they have high amp two pole and four pole kits for less than the one in the link.
