BB Distributor Drive Gears
#2433861
01/13/18 01:04 PM
01/13/18 01:04 PM
Posts: 10,704 North Dakota
6PakBee
North Dakota
I've been looking at the Hughes "OIL PUMP DRIVE SHAFT W/COATED STEEL GEAR". I really want to run a street hydraulic roller in a 383 but the choice of gear is concerning me. I've done some searches and the choices seem to be brass or coated steel (Melonized). I see Comp offers a composite gear but not for a BB. The comments I've read about the bronze gear seem to be like going to Vegas, you never know how it is going to end until after it's ended. Can't find much on the coated gear. What are your recent experiences with drive gears for street roller camshafts?
Re: BB Distributor Drive Gears
[Re: 6PakBee]
#2433881
01/13/18 01:54 PM
01/13/18 01:54 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I'm going to run the Hughes coated steel gear with my new roller cam. I've found running a well-adjusted collar on the distributor shaft really helped with reducing the wear on my previous bronze gears.
[Re: second 70]
#2433906
01/13/18 02:39 PM
01/13/18 02:39 PM
BradH
I replaced the bronze gear on my solid roller in my hemi with the Hughs gear and when I pulled it after a year of use to inspect it it and the cam looked new. Crane says not to run their gear on a used cam, FWIW.
[Re: second 70]
#2433931
01/13/18 03:21 PM
01/13/18 03:21 PM
Posts: 4,669 Wichita
GY3
Wichita
Crane 66970-1 on my Howards hydraulic roller. 2 years and 4,500 miles of street/strip use. I pulled it apart last fall and both the cam gear and distributor gear look new.
They do recommend using only with a standard volume and pressure pump. Not an issue for me.
[Re: GY3]
#2434383
01/14/18 01:23 PM
01/14/18 01:23 PM
6PakBee
North Dakota
Thanks to all who responded. Sounds like the coated steel gear is the way to go. I have done some more searching since my post and find that in addition to the standard oil pump, use of synthetic oil is beneficial also.
[Re: 6PakBee]
#2434407
01/14/18 02:05 PM
01/14/18 02:05 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I have a Lunati hydraulic roller (BTW - unless you keep the rpms really low I don't recommend it). They told me to send the mopar performance gear assembly to comp cams to get nitrided and never look back. That's what I did but don't have enough miles on it to comment how effective it is.
67 Coronet 500 9.610 @ 139.20 mph 67 Coronet 500 (street car) 14.82 @ 94 mph 69 GTX (clone) - build in progress......
