BB Distributor Drive Gears #2433861
01/13/18 01:04 PM
01/13/18 01:04 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
I've been looking at the Hughes "OIL PUMP DRIVE SHAFT W/COATED STEEL GEAR". I really want to run a street hydraulic roller in a 383 but the choice of gear is concerning me. I've done some searches and the choices seem to be brass or coated steel (Melonized). I see Comp offers a composite gear but not for a BB. The comments I've read about the bronze gear seem to be like going to Vegas, you never know how it is going to end until after it's ended. Can't find much on the coated gear. What are your recent experiences with drive gears for street roller camshafts?
Re: BB Distributor Drive Gears [Re: 6PakBee] #2433881
01/13/18 01:54 PM
01/13/18 01:54 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I'm going to run the Hughes coated steel gear with my new roller cam. I've found running a well-adjusted collar on the distributor shaft really helped with reducing the wear on my previous bronze gears.
Re: BB Distributor Drive Gears [Re: 6PakBee] #2433891
01/13/18 02:16 PM
01/13/18 02:16 PM
central il.
second 70 Offline
second 70  Offline
central il.
I replaced the bronze gear on my solid roller in my hemi with the Hughs gear and when I pulled it after a year of use to inspect it it and the cam looked new.
The gear is make by crane and installed on a shaft by Hughs. The only problem I had was the shaft was too tight in my bushing but a minute in the drill press and some emery cloth and all was well.
Mike
Re: BB Distributor Drive Gears [Re: second 70] #2433906
01/13/18 02:39 PM
01/13/18 02:39 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Crane says not to run their gear on a used cam, FWIW.
Re: BB Distributor Drive Gears [Re: BradH] #2433921
01/13/18 03:00 PM
01/13/18 03:00 PM
central il.
second 70 Offline
second 70  Offline
central il.
Brad I talked to them about it about it and it seemed they were worried about any wear the cam gear might have on it causing it to attack each other. Hughes told me that if all the bronze was totally off the cam it would work as long as the cam didn’t show any wear.
After over a year of street use I haven’t had any wear.
Re: BB Distributor Drive Gears [Re: second 70] #2433931
01/13/18 03:21 PM
01/13/18 03:21 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Crane 66970-1 on my Howards hydraulic roller. 2 years and 4,500 miles of street/strip use. I pulled it apart last fall and both the cam gear and distributor gear look new.
They do recommend using only with a standard volume and pressure pump. Not an issue for me.
'63 Dodge 330
11.19 @ 121 mph
Re: BB Distributor Drive Gears [Re: GY3] #2434383
01/14/18 01:23 PM
01/14/18 01:23 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Thanks to all who responded. Sounds like the coated steel gear is the way to go. I have done some more searching since my post and find that in addition to the standard oil pump, use of synthetic oil is beneficial also.
Re: BB Distributor Drive Gears [Re: 6PakBee] #2434407
01/14/18 02:05 PM
01/14/18 02:05 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I have a Lunati hydraulic roller (BTW - unless you keep the rpms really low I don't recommend it). They told me to send the mopar performance gear assembly to comp cams to get nitrided and never look back. That's what I did but don't have enough miles on it to comment how effective it is.
