Re: Transmission lines
[Re: A727Tflite]
#2435581
01/16/18 12:57 PM
01/16/18 12:57 PM
^^^ noted, thank you. On my next one I will tap/go to 3/8 line
[Re: cdwmotorsports]
#2438842
01/22/18 02:50 AM
01/22/18 02:50 AM
Posts: 1,441 Martinsville, IN
cdwmotorsports
Martinsville, IN
What trans. cooler are you guys running? I'd like to Drag Week my car in the next year or so. I'm looking at this one... Derale 13900 Derale Electra-Cool Remote Fluid Coolers 13900
eBay-cdwmotorsports
#2438856
01/22/18 03:50 AM
01/22/18 03:50 AM
people have said that the "stacked plate" types transfer more heat
[Re: rowin4]
#2439057
01/22/18 03:58 PM
01/22/18 03:58 PM
No, just mount it in the most convenient appropriate position for the easiest/shortest hose routing.
#2439267
01/22/18 11:49 PM
01/22/18 11:49 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
What trans. cooler are you guys running? I'd like to Drag Week my car in the next year or so. I'm looking at this one... Derale 13900 Derale Electra-Cool Remote Fluid Coolers 13900 I run a B&M stacked plate cooler, 8" 4500 converter, no fan, and nothing through the radiator. I have done 5 drag weeks with my road weight at about 4200lbs with passenger and gear. Now I do not have a temp gauge but I have run the same fluid for at least 8 years and it still looks good. The few times I have hit the trans cooler with a temp gun it has been 150-180* not that its much of an indication of fluid temp but I didn't think that was bad.
68 Barracuda Formula S 340
#2439447
01/23/18 10:42 AM
01/23/18 10:42 AM
Bad340fish
Tulsa OK
It is mounted down low in front of the radiator.
#2439565
01/23/18 02:55 PM
01/23/18 02:55 PM
an8sec70cuda
I use a trans cooler I bought from Advance Auto Parts about 20 years ago. Mounted in front the radiator. Works great, lol.
[Re: an8sec70cuda]
#2439585
01/23/18 03:42 PM
01/23/18 03:42 PM
cdwmotorsports
Martinsville, IN
That’s what I have but I want it plumbed with AN and braided line so I can save my stock lines for a later project.
eBay-cdwmotorsports
#2439593
01/23/18 03:55 PM
01/23/18 03:55 PM
an8sec70cuda
I have -6AN lines on it w/ a hose clamp. Backyard yes, but it works.
[Re: J_BODY]
#2439846
01/24/18 01:50 AM
01/24/18 01:50 AM
cdwmotorsports
Martinsville, IN
I use -6 line.... pipe to AN fitting on trans. Straight on the front, 45 degree on rear. Jbody, is the transmission side or hose side a 45 degree fitting? I can’t find a 45 degree -6AN to 1/8” NPT fitting anywhere
eBay-cdwmotorsports
